Results 1 to 10 of 25
Thread: I think it is the tank and not algae
    Jul 2006
    Default Re: I think it is the tank and not algae
    Hi Dave,
    Yes, water is exiting the pool, but within minutes some of the stuff is back on the bottom of the pool. We can vacuum to waste and see some stuff reappear immediately. Then, if we shut the filter down and restart it a few hours later, it looks like it all reappears around the outer edge of the pool (in the line of circulation). The backwash thing has me stumped too. In the past the water would come out with a lot of force during backwashing and there would always be some dirty water come out weekly. Not this year - we have about half of the pressure when backwashing and absolutely no dirty water coming out. A couple of years ago we had a huge algae bloom after a heavy rain and the water was totally green. We shocked and cleared it up and vacuumed the dead algae to waste one time. One time was all it took. My water has been clear all year. This stuff was on the bottom when we took the cover off in May and we still can't get it out. There is absolutely no slimy feeling anywhere in the pool and the water is clear. That is why I think it has to be the filtration system.
    Thanks!
    duraleigh Guest
    I suspect the filter as well but your answer is not clear to me. Let's try it another way.
    If you put the filter in "waste" or "backwash" position and turn on the pump, can you feel or see water going back into the pool?
    Jul 2006
    Oh my, I feel like such an idiot! Dave, I just went out to check, and yes - on waste I can feel a lot of pressure coming back into the pool. There is some on backwash, but not as much. Duh, why didn't I simply stick my hand in front of the return jet two months ago????? We couldn't see any water coming back in, or at least didn't notice it.
    So, what to do to fix this? Is it a spider gasket? My tank is just 2 or 3 years old.
    Thanks so much!
    duraleigh Guest
    Now you're makin' progress!
    The most likely culprit IS the spider gasket. The handle that's labeled "waste", "backwash", "filter", etc. is the multiport valve and the spider gasket is located down inside that.
    It is quite possible to locate the instructions for changing that out online. If you can find them, determine if it's a task you want to take on or have someone else do it.
    I know you have some algae/chlorine/water issues to deal with as well but I would suggest you fix the valve first (pretty soon) and then post back up and we'll all help you get your pool back to sparkling clear.
    Jul 2006
    Thanks Dave - my water is sparkling now - just has the debris on the bottom. We took of the multiport and located what we think is the gasket - it is the only rubbery piece on there divided into sections and is an off-white color. To me it looked okay, but hubby noticed it had a ridge around the outside with one side being high and the other being low and what looked like a pinch. He is on his way to get one now. If it isn't the spider gasket, do I need a new multiport? It appears to be turning correctly.
    Wow, I feel like I finally may win this battle! I'm just frustrated that I repeatedly told the pool store what was going on and they said "everyone is battling algae this year - you just have to keep shocking and vacuuming" - grr.
    IL.
    Quote Originally Posted by kbcpa
    Translation-
    "You're not alone. Our bad advice and incompetence is screwing all our customer's pools up."
    Jul 2006
    Rangeball,
    I was not trying to offend anyone, nor did I mean anyone here was incompetent. I was speaking about our local pool store and that is the only place I mentioned. Yes, I am frustrated that this has been going on for 2 months and I kept telling them the problem occurred when turning on the filtration. They never even mentioned a spider gasket to me, never suggested that I possibly had water going back into my pool when vacuuming to waste. I got that info here and am very thankful for the help I have received here. I have learned more on this forum in the past few days than I have from the local pool store.
    I apologize for offending, but I did not make a generalization about all pool stores.
    maybe a dumb question, but i'm assuming this is a sand filter? if so, is the sand nice and soft when you put your hand and run it through it, or is it hard?
    You are shutting off the pump before moving the multiport handle position correct?
    Jul 2006
    Yes, it is a sand filter. The sand was just replace about 6 weeks ago thinking that would alleviate the problem.
    As far as the handle, in the past we didn't turn the pump off before turning it - didn't know too (yes, although it says to right on the thing). We do turn the pump off now.
    So, I called the pool store where we bought the assembly and the lady was so nice (not the place that kept telling me I had algae and to shock). She said that it sounded like the hoses were hooked up incorrectly. And, she was right - we had the hose from the pump connected to the place where the water is supposed to go back into the pool. The hoses were reversed. This was the problem all along. Hubby switched them this evening and when he did, some crud blew back into the pool. He checked all positions on the valve and there is absolutely no water going into the pool on waste and backwash. We'll vacuum to waste tomorrow!
    Okay, pool idiot of the year goes to......me. I feel so stupid.
  1. Water tank? Swimming pool? both?
    By SimpleMark in forum In-Ground Pool Construction and Repair
    Last Post: 09-12-2011, 01:12 AM
  2. Please, advice for stock tank pool
    By Jjsabath in forum In-Ground Pool Construction and Repair
    Last Post: 07-04-2011, 09:04 PM
  3. Source for Jandy DEL60 tank???
    By Geeper in forum Pool Equipment & Operations
    Last Post: 07-01-2011, 03:24 PM
  4. My DE tank cracked.
    By JETTA in forum Above-Ground Pool Construction & Repair
    Last Post: 07-31-2007, 10:38 PM
  5. hole in sand filter tank
    By jaymst in forum Pool Equipment & Operations
    Last Post: 07-08-2007, 11:27 PM
