Results 1 to 10 of 19
Thread: Chlorine Enhancer ???
    Rocket City, AL, USA.
    Default Re: Chlorine Enhancer ???
    I'm confused. You've been using the tri-chlor pucks in a floater, yet your CYA is ZERO??
    How did you test for you CYA? If you have been using the tri-chlor pucks for any length of time at all, your CYA level should not be zero.
    Jul 2006
    Tucson, AZ
    Raddish-
    Was using pucks from WalMart(not sure what kind of chlorine in them).My water starting looking cloudy right before the 4th. I had my water tested at the pool store and all of my levels were good. I can't remeber the exact numbers but all was good. My CYA was fine too.They sold me Green to Clean because I thought I was getting algae. I shocked used the Green to Clean and shocked again with the powder shock. The water was looking better on the 4th. We had a big bbq for the and lots of pool use. The next day the water was very cloudy,bluish-grey. I kept shocking and leaving the filter running and nothing. My chlorine would not keep. The water is not cloudy anymore, but it is green. Yesterday I had the water tested at the same pool store as before and my CYA was zero. I meant to ask does that seem right. How would I lose my CYA so quickly. We did have A LOT of rain, it's Monsoon Season here in Tucson.Would that cause the CYA do totally diminish?
    Mandy
  1. Chlorine tabs vs chlorine bleach generic
    By Cahoonh in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-13-2013, 10:28 AM
  2. High Chlorine Level with no Chlorine Added in 6 weeks
    By morechoff in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-27-2006, 08:52 AM
  3. Free Chlorine vs. Total Chlorine adjusting
    By Truckman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-08-2006, 06:00 PM
  4. alternatives to chlorine/non-chlorine pool maint
    By leewest in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 04-04-2006, 11:53 PM
