Thread: Stabilized Chloramine?
    CToon is offline Registered+ Thread Analyst CToon 0
    Elkins Park,Pa
    Default Re: Stabilized Chloramine?
    The plus side to this is you've discovered the good side of having a high cya level , CL doesnt burn off that quickly. The only thing is with cya where it is you need to keep the cl where it is now according to the best quess chart
    It's hard to tell without drop-testing, but if those numbers are right, things sound OK. Everything in pool chemistry is a balancing act.
  1. Why does stabilized CL test as fc instead of cc?
    By Themadczar in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-29-2013, 10:10 PM
  2. non stabilized chlorine
    By nisqu in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-09-2008, 07:03 PM
  3. Can you get that 'chlorine/chloramine' smell from an SWG??
    By human in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 09-22-2006, 01:52 AM
  4. HTH Non-stabilized chlorine tablets
    By vanhout in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-03-2006, 10:42 AM
