Thread: Just wait or add something?
    Jul 2006
    Hot, Dry Texas!
    Default Just wait or add something?
    My numbers are all "within range" but I have a cloudy pool, there is lots of minute particles floating around, I am reisiting the urge to add a floc or a clafiier for obvious reasons, but I am wondering if I need to just let the filter do its job and wait a few days for it to clear up or can I do something that will jump start it? I am willing to just wait a few days, or add something that won't mess up all my numbers. This is the first time in several weeks all my numbers have been within range, I have been vaccuming and backwashing, I added 7 bags of shock last weekend( before I found this site) and have lots of oxidation( I guess) floating around.
    I am perfectly ok with letting it go on its own, do you think I could get a skimmer sock and it would help? Or add some DE to the sand filter?? Just want my clear water back!!
    Mandeville, LA, USA.
    Default Re: Just wait or add something?
    Mom, A skimmer sock and/or DE in your sand filter certainly won't hurt anything and may well help.
    I think you'll get more meanigful responses if you post your actual chemisty numbers instead of "in range".
    In the meantime, here's an article by Ben on reasons for cloudy water: http://www.poolsolutions.com/gd/cloudy.html.
    Be patient and let the pump run. I'd add DE/sock also and next time you add chlorine, just use bleach. Bags of shock you're using adds calcium and can increase cloudiness.
    Jul 2006
    Hot, Dry Texas!
    Quote Originally Posted by day1
    I am so DONE with the bags of shock, but I just need to get the "remnants" of the last bags I added over the weekend... I am running the pump 24/7 and I am going to get a sock and try it, it def won't hurt anything will it?
    The sock won't hurt anything. Nor will the DE unless there's a problem with your sand filter (e.g. channeling in the sand that will let the DE through; something that you probably can't rule out at this point).
    Jul 2006
    Hot, Dry Texas!
    OK, well here ya go then...
    TC=10
    FC-10
    CYA=85
    PH=7.4
    ALK=120
  1. Ph and alkalinity low, should I wait to adjust
    By Cincin5000 in forum Dealing with Alkalinity and Calcium
    Last Post: 05-28-2012, 01:08 PM
  2. how long to wait
    By cloudy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-11-2010, 10:27 PM
  3. Animal Poo and How Long to Wait
    By SoCalBoo in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-12-2006, 04:44 PM
  4. While my pool lies in WAIT ...
    By debs_pool in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-22-2006, 02:18 PM
  5. how long to wait to shock
    By Sunny32504 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-23-2006, 10:49 PM
