Results 1 to 3 of 3
Thread: Return Eyeballs
    Westminster, MD.
    Default Return Eyeballs
    Does anyone know where I can purchase adjustable eyeballs for my returns? I need to divert the water some, and haven't found any place local that sells them. Any place online?
    Thanks!!
    Berwyn, PA
    Default Re: Return Eyeballs
    I got some several years ago at a Leslie's store, but I also see some here. You'd have to measure to make sure you've got the right size.
    23' x 41' 32k gal plaster circa 1991, 600 gal spa with overflow
    Ultraflow pumps, Titan SS filter, Sta-Rite heater, Polaris 180
    Homegrown X-10 automation -- filter, cleaner, valves, lights, chlorination
    we just ordered one from intheswim.com...it was just a few dollars (plus the dreaded HANDLING CHARGE!) so if you are ordering a bunch of stuff, it would be worth it...
    I see you are in my neighborhood, if i'd known, i could have tagged one onto my order...
    check your PM's
  1. return jet
    By sun and water in forum Pool Equipment & Operations
    Last Post: 07-21-2012, 12:30 PM
  2. Return of the algae
    By essikr in forum Dealing with Algae & Slime
    Last Post: 09-20-2011, 03:30 PM
  3. Return from Vacation
    By cschnurr in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-05-2006, 07:25 PM
  4. Air in Return lines
    By berardi17 in forum In-Ground Pool Construction and Repair
    Last Post: 07-02-2006, 04:51 PM
  5. 24 agp return leak
    By cvoytek in forum In-Ground Pool Construction and Repair
    Last Post: 05-29-2006, 10:13 AM
