Thread: 1st Test with PS234 W/ copper test
    Default 1st Test with PS234 W/ copper test
    I just received my new PS234 test kit and these are my numbers:
    FC: 1.5
    CC: .5
    TC: 2.0
    PH: 7.6
    Alk: 110
    Cal: 60
    Cya: 50-60
    Temp: 82 Degree
    Copper (Cu): .15ppm
    I have a 18x36 vinyl inground, 24000 gal pool that I installed myself. From lurking in this forum for a while, I know I need to increase my alk (getting baking soda this evening - we have had over 15 inches of rain the past two weeks).
    I know I don't have to worry about the calcium level.
    My question is - how does my copper level look?
    I installed a Frogger mineral system (before I found this forum) and I need to check the copper level so I don't turn hair green.
    Am I in the ball park with my thinking?
    Thanks for reading
    Jeff
    Default Re: 1st Test with PS234 W/ copper test
    Bump - Anyone?
    duraleigh Guest
    Jeff,
    I know it's not your question, but you need chlorine in your pool. You should be somewhere around 4-7ppm constantly.
    If your CC tests at 1.0 or greater in the future, you'll need about 16-18ppm for a successful shock.
    I don't know a thing about acceptable copper levels but I am curious as well....just can't help.
    Sanford, FL
    I think your ALK level is fine - I think 90-120 is normal??? Someone can verify. The copper can precipitate out at high chlorine levels (like when you shock - which looks like you need to with the CC reading). Try Jacks Magic before you shock to sequester the metals.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    Smile Re: 1st Test with PS234 W/ copper test
    Thanks for the replys
    Jeff
  1. PS234 Test
    By Bruce A in forum DPD-FAS based testing
    Last Post: 07-16-2006, 08:25 PM
  2. first PS234 test
    By newtopools in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-24-2006, 07:04 AM
  3. Necessity for ordering Salt Test in PS234 test kit
    By Scarlett in forum DPD-FAS based testing
    Last Post: 06-13-2006, 12:04 AM
  4. First test results with the PS234
    By metalman in forum DPD-FAS based testing
    Last Post: 05-26-2006, 10:20 PM
  5. First test with PS234
    By tbatti in forum DPD-FAS based testing
    Last Post: 05-13-2006, 11:04 AM
