Thread: 1st test results
    Jul 2006
    Default 1st test results
    Hi everyone. here are my first test results ps234
    fc 8
    cc 0
    tc 8
    ph 7
    alk 240
    cal 360
    cya 0
    temp 80
    24' ag 13800 gallon
    I've already been adding muriatic acid and just started areating last night.
    should I start bringing my cya up now or wait till I get the alk down?
    Thanks for all your help
    duraleigh Guest
    Default Re: 1st test results
    Good morning,
    To the best of my knowledge, CYA will not affect lowering your alkalinity in any way. I'd get it in there.
    You have a good understanding of the pH and Alk adjustment you need....good work. Put in that CYA and Go Swimming!!
    Jul 2006
    Thanks Dave. Will do.
  1. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  2. First 234s test results and warning about pool stores' results
    By SoCalBoo in forum DPD-FAS based testing
    Last Post: 06-16-2006, 02:48 PM
  3. First test results
    By poolbee in forum DPD-FAS based testing
    Last Post: 06-15-2006, 11:27 PM
  4. First Test Results
    By Cutter in forum DPD-FAS based testing
    Last Post: 06-14-2006, 08:30 PM
  5. first test results
    By jazzbone in forum DPD-FAS based testing
    Last Post: 05-26-2006, 04:19 PM
