Thread: Will Yellow Treat just eat away chlorine
    Madty is offline ** No working email address ** Thread Analyst Madty 0
    Default Will Yellow Treat just eat away chlorine
    I shocked to about 15 from 5 cl then added Yellow Treat. I also added 3 lbs of CYA to bring up from 12. After a couple of hours my orange oto cl test at 15 was down to about 1-2/ Is that normal. It says to wait 24 hrs before shocking again, but I think I need to keep the cl levels high- correct? Yes, mustard algae.
    tundraSQ is offline Established User Thread Analyst tundraSQ 0
    Default Re: Will Yellow Treat just eat away chlorine
    I belive Yellow treat is a bromide based product...if so then yes it will gobble clorine. I added a quart of sodium bromide to kill my mustard algae...and then I just kept adding chorine like crazy to keep te levels up (above 10 for me)...and it worked. Took about a week. Waterbear has posted some good info about bromide products if you do a search.
  1. Yellow stain on steps from chlorine tablets
    By Chuppet in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-21-2012, 10:22 PM
  2. High Chlorine but still some yellow Algae on walls
    By stevetuck in forum Dealing with Algae & Slime
    Last Post: 06-05-2012, 08:48 AM
  3. Keeping the Chlorine up and light yellow stains
    By jonnygib in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-01-2007, 11:42 PM
  4. How To Treat The Water??
    By bsbrega in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-04-2006, 09:52 AM
  5. Treat water or drain?
    By jimk0512 in forum Dealing with Algae & Slime
    Last Post: 07-30-2006, 03:37 PM
