Yes. Stop adding "Chlorine granules" and stick to bleach if those granules are di-chlor powder. If they are Cal-Hypo, it's OK to use them until calcium/hardness approaches 400ppm.Originally Posted by Xignals
Another: Your CYA is 50 but your FC and TC are 2. They should be between 3 and 6--and at 50 I'd keep FC between 5 and 6. (unless you have an SWC).
And, with your pH at 7.8, your risk of algae is even greater. 7.8 is OK, but you DEFINITELY want your FC and TC to be in the 5-6 range.
It's not that your numbers are bad--they are pretty good, but only pretty good. It's that you have put yourself closer to being at risk than you should. Were it me I would do 3 things given your numbers:
1) Only use bleach to chlorinate.
2) Get FC up to the 5-6 range ASAP.
3) Slowly get pH down to the 7.3 to 7.6 range.
Of the 3, I think 2) is most important.
