Thread: What PSI should a filter run at?
    Default What PSI should a filter run at?
    I have a Star DE-50 filter and a Dynamo 1hp pump. I also have an automatic chlorinator hooked up between the filter and the return. My filter pressure is at 12. Is that ok? Is that high or low? I have no clue and the directions didn't say what a normal pressure is. I've checked everywhere! Anyone know?
    Sherra is offline Lifetime Member Weir Watcher Sherra 0
    South Carolina, United States.
    Default Re: What PSI should a filter run at?
    That sounds within normal range to me. A lot of factors go into the pressure, so differences from one pool to another are totally normal. The exact same pool size with the same filter and pump can even run at different pressures. My pressure runs around 14 or 15 on my 60" filter w/ 1 HP pump.
    Sherra
    Kershaw County South Carolina
    (previous AG pool owner)
    Rehoboth, MA
    I think the only thing that matters is that you know what the pressure is when your filter is clean so that you can tell when the filter needs cleaning by a rise from the normal pressure.
    My pressure runs about 10 psi when my solar mat is bypassed and 15 psi when not bypassed.
    Peter
  1. Sand filter vs cartridge type filter
    By stevens23 in forum Pool Equipment & Operations
    Last Post: 07-12-2012, 07:54 AM
  2. Sand Filter and Cartridge Filter Owners Please Advise
    By amati5 in forum Pool Equipment & Operations
    Last Post: 08-30-2011, 06:05 PM
  3. Help! Switching out 1985 cart filter to sand filter
    By JLICHTY in forum Pool Equipment & Operations
    Last Post: 06-18-2011, 11:09 AM
  4. Replies: 7
    Last Post: 05-16-2010, 09:46 AM
  5. Changing Sand in Filter and Random Filter Question
    By newbie2pools in forum Above-Ground Pool Construction & Repair
    Last Post: 07-24-2006, 03:38 PM
