Results 1 to 4 of 4
Thread: Ascorbi c Acid
    Default Ascorbi c Acid
    How much ascorbic acid do you use in a 36,000 gallon vinyl line pool to remove the stains caused by well water?
    mbar's Avatar
    mbar is offline Lifetime Member Whizbang Spinner mbar 3 stars mbar 3 stars mbar 3 stars mbar 3 stars
    Ashland, PA
    Default
    Usually about 1 lb per 10,000 gal. I have used less - I would try 2 lbs first, I usually walk around the pool dropping it down the sides. Let the water cirulate (put the pump on circulate not filter) for about 1/2 hour. If all the stains are gone, you won't need any more. You will see that the staining comes off very quickly - if not all of the stains are gone, then add more where you see them the heaviest, let it circulate some more. When the stains are gone, put in the metal free (sequestering agent). Let circulate about 1/2 hour more, then put the pump on filter, and keep it on filter 24/7 for at least 2 days. Keep your ph at 7.2, it will be hard because the stain treatment is very acidic. After 24 hours put a chlorine puck in the skimmer. After 48 hours you can start to raise your chlorine - do not shock for at least 2 weeks. If you have any questions, feel free to ask.
    Here is link:
    http://www.msm-msm.com/store/agora.c...scorbic%20Acid
    Northeast PA
    16'x32' kidney 16K gal IG fiberglass pool; Bleach; Hayward 200lb sand filter; Hayward pump; 24hrs; Pf200; well; summer: none; winter: mesh; ; PF:7.5
    Default Thanks,
    Quote Originally Posted by mbar
    Here is a link for ascorbic acid:
    Thanks M.That is a big help. The link you posted did not work. Any more suggestions on where to buy?
    David
    mbar's Avatar
    Ashland, PA
    Default
    Northeast PA
  1. Where to buy CYA? & acid ?
    By PJM361 in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-03-2012, 01:13 AM
  2. Dry acid vs Muratic acid
    By jackinlv in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-25-2011, 01:44 PM
  3. Lowering TA with Dry Acid Or Muriatic Acid
    By CelticDaddio in forum Dealing with Alkalinity and Calcium
    Last Post: 07-05-2007, 01:54 AM
  4. Too much acid?
    By k2vell in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-07-2006, 10:57 PM
  5. Dry acid versus muratic acid - and how to add?
    By west1745 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-03-2006, 01:19 AM
