Results 1 to 10 of 21
Thread: sta rite system 3 cardtidge as good as de?
    Jul 2006
    Default Re: sta rite system 3 cardtidge as good as de?
    Quote Originally Posted by Rangeball
    I've had the pentair FNS+ 36 for several years now. No mechanical issues at all.
    So far this year, I've not had to backwash or clean once. It's amazing what happens when you stay ahead of your pool I am at 13 now, but I'm pretty sure it's due to cotton wood trees with no skimmer sock.
    My filter pressure runs at 10 psi at start up. It's recommended to backwash when it goes up 10, so for mine at 20 psi. What I do after I've backwashed is add de slowly back to it until the pressure again hit's 10 psi. This way I can avoid a complete teardown unless absolutely necessary.
    yeah, i've pretty much decided on this one over the last couple days. i've found it shipped with a multiport for under $500, so i think i'll order soon.
    do you mind my asking how big you pool is and how long you run your pump?
    IL.
    22,000 gallons, I run my pump 24/7. Not needed, I think my water cycles in 6 hours, it's just something I've always done, and since my water stays clean, I'm afraid to mess with it by running less.
  1. Sta-RiteŽ System 3 Air Bleed Filter
    By meghanW in forum Pool Equipment & Operations
    Last Post: 08-24-2012, 09:33 PM
  2. Converting Sta-Rite system 3 cartridge to DE
    By kidjetta in forum Pool Equipment & Operations
    Last Post: 07-07-2011, 03:58 PM
  3. Sta-Rite System 3 Cartridge Filter - Can I convert to sand using the same housing?
    By sqwarecocci in forum In-Ground Pool Construction and Repair
    Last Post: 04-22-2011, 06:45 AM
  4. Sta Rite equipment good?
    By Pool_Mike in forum Pool Equipment & Operations
    Last Post: 07-14-2006, 09:06 AM
  5. Laterals in Sta-Rite System 3 sand filter
    By Area Man in forum Pool Equipment & Operations
    Last Post: 05-27-2006, 09:00 AM
