Results 1 to 10 of 21
Thread: sta rite system 3 cardtidge as good as de?
    Jul 2006
    Default Re: sta rite system 3 cardtidge as good as de?
    thanks alot for helpfull (on topic) replies. i think i'd also prefer the de, so i may just do the teardown instead of backwashing when needed. it shouldn't be too often as the 36 sq ft is pretty oversized for my pool. as a side note, i've since found out that long beach,ca doesn't even allow backwashing of DE to the sewers without a separator anyway. only sand can be backwashed to the sewer without treatment.i figure i can get by with the breakdown method till i'm forced to buy a separator.... does anyone forsee any major problems with a plan like this?
    on this note, since the separator is just a second trap, is there any reason to spend alot on one? should i just try to go cheap? also, i heard that adding a separator can decrease the backwash effectiveness due to gpm limiting characteristics...
    I guess this is kind of like a religous debate or coke/pepsi but I'll throw in my .02 I have tried both modern DE and cartridge systems and prefer the DE. I suppose a small cartridge may be easier to deal with than a DE filter but the 4 cartridge large sq/ft hayward is a big pain to clean and takes several hours if you want to clean it well. Sure you can take it out and give it a quick squirt and throw it back in the filter and consider that a cleaning job. But dirt/grime really gets into all those little pleats and it seems to take forever to clean those.
    After 1 year with my 4 cartridge hayward I decided to switch to DE because I figured DE couldn't be any harder than the darn cartridge to clean and to replace 4 cartridges costs a small fortune, almost as much as a new filter. I was amazed at the clarity difference it made as well. Perhaps my cartridges were just bad but they were not even 1 year old, but the DE made the water really sparkle. And at night you can definately tell a difference by looking in front of the light.
    Because my DE system had a problem I ended up tearing the system down a couple times to find a hole and didn't find it very difficult at all, it was faster than a full clean of 4 cartridges. So I am definately sold on DE over cartridge. I can't say anything about sand as I have never tried it.
    -- john
    Jul 2006
    i gues now i'm looking into separation tanks (which should maybe be another thread). in addition to the innefficiency during backwash question above, does anyone here have experience using one where you return the separated water to the pool? most manufacturers say that you can do this, but it seems to me, that unless the tank filters as well as a de filter, you'd get a buch of crud making it past the sep tank and back into the pool. does anyone have any experience with this?
    IMHO (and this will probably start another debate!), DE filters should be broken down and cleaned, not backwashed. My reasons are as follows:
    1. when you back wash you really don't know how much DE has washed out so you really don't know how much DE to replace...too little and you will not have good filtraton...too much and you might get bridging between the grids (and if you have ever had to pick away at rock hard DE stuck between the grids you understand what I mean!)
    2. Backwashing forces water backwards through the grids....If you run a DE filter without DE, even for a short time, you run the risk of dirt clogging the grids and the grids getting coated with oils and organics. You then have to break the filter down and clean the grids...when you backwash you are still forcing dirty water through the grids (backwards) and the same thing can occur.
    As far as "bumping' a DE filter....knocking the DE off the grids so the dirt can mix with it and then recoating the grids is not a good idea, IMHO. Dirty DE is dirty DE!
    Just my 2 cents!
    Honesdale PA
    One final note from me on this thread. Anyone contemplating buying a filter should read all the stuff that's been posted on this forum and the 'pool construction and repair' and 'AG pool equipment and construction' forums before making a decision. The subject of filters has been discussed in great depth and there are all kinds of views concerning water clarity, cost, and maintenance.
  1. Sta-RiteŽ System 3 Air Bleed Filter
    By meghanW in forum Pool Equipment & Operations
    Last Post: 08-24-2012, 09:33 PM
  2. Converting Sta-Rite system 3 cartridge to DE
    By kidjetta in forum Pool Equipment & Operations
    Last Post: 07-07-2011, 03:58 PM
  3. Sta-Rite System 3 Cartridge Filter - Can I convert to sand using the same housing?
    By sqwarecocci in forum In-Ground Pool Construction and Repair
    Last Post: 04-22-2011, 06:45 AM
  4. Sta Rite equipment good?
    By Pool_Mike in forum Pool Equipment & Operations
    Last Post: 07-14-2006, 09:06 AM
  5. Laterals in Sta-Rite System 3 sand filter
    By Area Man in forum Pool Equipment & Operations
    Last Post: 05-27-2006, 09:00 AM
