Your test results don't look too bad, except TC of 3 isn't high enough for CYA of 80--you should have it closer to 5 or 6. Your TA is still a tad high,but in a vinyl pool with the lowered calcium, it shouldn't cause you a problem. I wouldn't use cal-hypo products to chlorinate/shock with, though, because it'll make your Ca go up again and the high Alk can cause you some cloudy water problems.
