Thread: foam in our pool
    Jul 2006
    Default foam in our pool
    Help ! When we run our filter there is a foam on the surface...we use bacquacil and a sand filter the sand has just been changed
    Jul 2006
    Default Re: foam in our pool
    I had the same problem yeasterday, and I use baquacil and a sand filter. I hope to find a cure soon!
    Front Royal, VA
    I've always seen a higher occurance of bubbles and foam when putting in the biguanide and clarifier. If all your levels are normal, I wouldn't be too alarmed.
  1. Help. Correcting zero chlorine level & some foam in Intex type pool after dust storm
    By h20pup in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-03-2013, 12:16 PM
  2. Foam Wall Liner won't stay attached to pool wall
    By pdxpool in forum Above-Ground Pool Construction & Repair
    Last Post: 07-02-2012, 04:24 PM
  3. new to the pool forum wish I had found you sooner, wall foam ?
    By blackthumb in forum Above-Ground Pool Construction & Repair
    Last Post: 06-29-2011, 04:07 PM
  4. Doh! Foam Party In My Pool!
    By troykristoffer in forum Dealing with Algae & Slime
    Last Post: 08-03-2006, 09:50 PM
