Results 1 to 3 of 3
Thread: Kit Results
    USA.
    Question Kit Results
    Received the PS234 new kit - I think I had finally gotten things under control but its nice to get confirmation using this kit.
    FC = 8
    CC = 0
    TC = 8
    pH = 7.2
    Alk - 80
    Cal = 240
    Cya = 50
    Temp = 80F
    pH needs a little bump and the Cya is a little higher than ideal.
    Where can I find info on the 'ideal' ranges for these readings and how tyo adjust them if needed - the kit did not include that info?
    Also how do I register my Serial number (#6440) to upgrade my membership from 'registered' to 'kit owner'? - is this thread sufficient?
    look forward to the feedback - T
    Sherra is offline Lifetime Member Weir Watcher Sherra 0
    South Carolina, United States.
    Default Re: Kit Results
    I'm not at home right now, but I made a spreadsheet up that had my "ideal" range numbers on it. I got them by cruising through the poolsolutions.com site and picking the numbers off the various places on there. Your "ideal" numbers may vary a little depending on what type of pool you have.
    As for registering your kit and getting your membership upgraded...you need to send Ben a private message or an e-mail.
    Sherra
    Kershaw County South Carolina
    18x34 IG 2' radius rectangle vinyl liner (approx 27,500 gal) 1 1/2" pipes installed March 2006
    (previous AG pool owner)
    Maine, USA
    FWIW, I've sent 3 or 4 Private Messages to Ben and received no response. 2006 is more than half over.
    Regards,
    Ron [ muvipix.com ]
  1. first results, please help
    By vinouspleasure in forum DPD-FAS based testing
    Last Post: 06-13-2010, 01:42 PM
  2. More 234 results
    By drband in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-22-2006, 01:49 PM
  3. Pool store results vs my ps223 results!
    By scarywoody in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-20-2006, 05:47 PM
  4. First 234s test results and warning about pool stores' results
    By SoCalBoo in forum DPD-FAS based testing
    Last Post: 06-16-2006, 01:48 PM
  5. First set of results
    By maker in forum DPD-FAS based testing
    Last Post: 05-25-2006, 08:48 PM
