Originally Posted by CarlD
I'm not sure the idea that the stuff in the filter is past rotting is valid. Last summer I got a new DE filter. The dealer did not supply the multiport valve so I could not backwash. The instructions, as usual said to backwash after noting a pressure rise. After 2 month my pressure only went up 1 1/2 lbs so according to the bood, it didn't need a backwash. But I decided to open it up and hose it off anyway.
I was astonished at the amount of cr@p on the DE. The smell was horrendous. The pool water still showed negligable CC and the FC was held pretty steady at about 5 PPM so it looked OK externally.
But inside YEAUKKKKK.
Next cycle I opened it up again after 1 month. Virutually the same mess. The chlorine does not really break down the stuff in the filter the way I expected it to. Now I clean the filter every two weeks. The blankety blank dealer still has not send the backwash vales so I still do it the hard way. But I won't every leave it for a month or two.
Try taking a 5 gallon pail and catch some of the backwash water about a minute after the flow is reversed. Pretty disgusting.
