Results 1 to 10 of 33
Thread: Bleach same as Chlorine
    Jul 2006
    Red face Bleach same as Chlorine
    I see everyone talking about using bleach, is that the same as using chlorine?
    Thanks!
    I'm a rookie here!
    Sun Prairie, WI
    Default Re: Bleach same as Chlorine
    Yes it is.
    ~Dr. Spike
    Pool: IG vinyl, heated, fully enclosed (dome)
    Shape: Grecian (rectangular)
    Size: 20'W x 40'L
    Depth: 4' / 8'
    Filter: Sand w/DE added
    Other: 6' Diving Board
    Maintenance: BBB! Ben's PS234 kit! Manual vacuum, brush, and Pool Buster Max CG Gold
    Jul 2006
    Thank you.
    Liquid chlorine from the pool store is Sodium Hypochlorite solution. So is regular and ultra bleach. Only the concentrations vary.
    so does replace chlorine tablets throughout the season? Just buy the bleach instead?
    That's a different question. My answer would be "yes".
    All chlorination chems ultimately add chlorine and it doesn't matter the source.
    HOWEVER, each chem has other effects: Tri-Chlor tablets lower pH and add lots of stabilizer.
    Di-Chlor powder lowers pH too, but not nearly as much. It also add stabilizer--a lot but not as much as Tri-Chlor.
    Cal-Hypo adds calcium and tends to raise pH.
    Lithium and potassium chlorites empty your wallet INCREDIBLY quickly.
    Only bleach/Liquid chlorine has almost no side effects.
    Carl, that is not quite true. Most of what you said is 100% on, but bleach does tend to raise the pH quite a bit. At least in my experience.
    I've heard that some people have found that bleach raises pH. It is not my personal experience, though.
    Quote Originally Posted by CarlD
    That is really strange, because if you tested the pH of bleach you would find it off the chart (to the high side). I find that my pool stays at a perfect pH level if I use a mix of 3" pucks which drop the pH and Bleach which raises it.
    Default Re: Bleach same as Chlorine... So what should I have on hand to get through summer???
    So will all the following get me through the summer barring no "funny business"????
    1. Generic Bleach (this is my chlorine to use... I don't need the tablets with Tri or Di chemicals in them?)
    2. Borax
    3. Baking Soda
    4. Muriatic Acid
    5. Cyanuric Acid
    6. 6 Way tester from HTH
    7. Bathing Suit
    8. Floaties
    AG 8,500
    Sand Filter
  1. Chlorine tabs vs chlorine bleach generic
    By Cahoonh in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-13-2013, 09:28 AM
  2. Chlorine / Bleach
    By ts8181 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-01-2011, 06:31 AM
  3. Bleach as Chlorine
    By hancop in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-19-2006, 10:33 PM
  4. Bleach vs Chlorine Help.
    By MaxxFusion in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-30-2006, 10:37 AM
