Thread: chlorine directly into skimmer. D.E Filter
    Default chlorine directly into skimmer. D.E Filter
    Is it ok to pour chemicals directly into the skimmer, with a D.E filter? Chlorine or Acid. I usually just pour them into the discharge area. wondering if it will hurt the filter fingers etc.....
    duraleigh Guest
    Default Re: chlorine directly into skimmer. D.E Filter
    Everything but acid is the general consensus.
    Including dry chemicals also? Baking Soda etc..........
  1. Are chlorine skimmer sticks or pucks OK?
    By rick24 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-22-2011, 10:52 PM
  2. will stabilizer poured directly into pool hurt the liner?
    By rastoma in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-12-2009, 02:49 PM
  3. Chlorine Tablets in the skimmer
    By mdjjpapa in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-29-2008, 08:30 AM
  4. Need pump, filter and skimmer recomendations?
    By mjs31 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-18-2007, 11:17 PM
  5. Pump/skimmer Or Filter Problem - Not Sure
    By niklepikle in forum Pool Equipment & Operations
    Last Post: 05-27-2006, 11:33 AM
