Results 1 to 10 of 25
Thread: I found a water boatmen in our pool...
    Oklahoma City
    Default Re: I found a water boatmen in our pool...
    Hey Joe! Thanks for the reply! I broke down today and bought combat 60 to kill them. We have so many, we don't even want to get in. The pool guy said that it would do the job but after reading the bottle it looks like it is to help with preventing algae. This is also our first year with the pool and our neighbor said the same thing you said about having them bad the the first year they had their pool. Anyways hope this does the job! Thanks again for your reply!
    Michelle
    Quote Originally Posted by MBeardsley
    Michelle
    Michelle,
    Would you mind posting the ingredients of the "Combat 60". I have not heard of it and couldn't find anything on Google. Wondering if it is something that reduces the surface tension of the water therefore preventing the little buggers forming the air sac that enables them to stay under so long.
    Joe
    Joe
    27ft 17K gallon Polytech aluminum & stainless AG Pool / DE filter / Wedding Cake Steps
    michladny is offline ** No working email address ** michladny 0
    I am FREAKING OUT as I was cleaning the pool today (as I vacuum twice a week) and this things swims by the pole UNDER the water like it is enjoying itself !!!!!!!!!!!!!!! I HATE, HATE, HATE, BUGS and I CERTAINLY do not want them sharing my pool !!!!!!! I managed to catch him and put him in a jar and he is swimming around in there....... so I have to smush him to get rid of him????? This is the first time since May 19th (when the pool was put up) that I have found something like this...... EWWWWWWWWWWW---kinda takes all of the enjoyment out of the pool for me. This thing swims on his back and has dagger like front legs/fangs and long hind legs that look like oars.
    YUK YUK YUK
    HEY...that sounds like a great idea - drain water: add bleach !!!! Maybe the entire family can swim in bleach instead of water.......
    I did find this on the net last evening:
    1. "I have a huge problem with the backswimmers in my pool. I have spent a few hundred dollars and a lot of time to try and get rid of them........... All you have to do is get BioGuard brand Back-Up algaecide and put the whole bottle in your pool. I just put it in an hour ago and there are at least 50 dead bugs floating at the top of my pool.............." http://www.faqfarm.com/Q/How_do_you_...mers_in_a_pool
    helix2000 is offline ** No working email address ** helix2000 0
    Jul 2006
    We have an above ground pool that we keep very clean, and we have both waterboatmen and backswimmers (about 4 - 6 per week). If you see both of them, you can tell the difference. The wb are slighly smaller, lighter in color (gray) and seem to stay by the sides of the pool (they feed on any algee in the pool).
    The bs are larger in size, darker in color (closer to black), much faster swimmers and swim all over the pool. They also bite but wb do not. If you can look at one closely when it comes to the surface, you can actually see it's nasty little legs curled up on top of it since it swims on its back.
    The bs eat the wb and other water bugs in the pool. Guess that is why they are larger because they have a belly full of wb.
    We have not found a way to keep them out yet. I am going to try that Bioguard product. For now, I just walk around the pool and can usually spot them and get them out with a net and crush them. I won't get into the pool until I have thoroughly checked it. They both creep me out.
    I have also heard of mixing dish soap in a water bottle and spraying the top of the pool so they can't come up for air. I don't know if this works, but it may be worth a try for a smaller pool.
    Morris, IL
    Quote Originally Posted by helix2000
    I don't think that is a good idea. Read this post here.
    Um, unless you want to deal with a copper problem next, I would not use Bioguard Backup algaecide to kill the water bugs....
    Jul 2006
    Sorry, I didn't mean in large amounts like that. That is nut's!
    I read that if you take a tblsp of dawn and mix it with water in a spray bottle and then spray a light layer over the top of the pool, this prevents the bugs from breaking the surface and getting air, so they drown.
    Like I said, I don't know personally if this works, but the people who posted it said it worked for them, but I think they had an above ground.
    karrde97 is offline Registered+ Thread Analyst karrde97 0
    Peoria, IL
    We put our pool up July 4th and have caught 100+ in the skimmer. My son makes a game of it with goggles and a net. The other I rattled the ladder and out they came. 1huge one and a bunch of liitle ones. They were immediately caught in the net and exterminated with extreme prejudice. We've had the solar cover on for a couple days. I hate to see what's living in there now.
    21' AG 48" AquaLeader
    Central Illinois
    Sacramento, CA, USA.
    There are a couple of products designed to help control these bugs. One is "Bug Out" and the other "Bug Away." Ask a dealer.
    These bugs actually use a primitive lung on their abdomen. They trap a bubble of air and use it to breath. The products reduce the surface tension of the water so that bubbles can't form and the critters drown. Generally what happens is that they will fly (yes, they fly) into the pool and try to trap a bubble. If they can't they will try to fly away. The ones in the pool will drown. Either way, the idea is to interrupt the breeding cycle and they will go away. You can scoop out the dead ones, let the skimmer get them or your auto cleaner.
    The small ones are generaly just an unsightly nuisance, the big ones are the "mamma" and will bite. They can live in highly chlorinated water. I have found them inside floating chlorinators happily sitting on the tablets.
  1. Water Boatmen in my pool...
    By Grahamrolph2 in forum Pools, Pets and Creepy Critters
    Last Post: 07-26-2012, 05:38 PM
  2. new pool glad i found this forum
    By udg21 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-28-2012, 08:28 PM
  3. Found this Turtle in my pool
    By Graves in forum Pools, Pets and Creepy Critters
    Last Post: 05-28-2011, 07:21 PM
  4. Water boatmen!!
    By CanuckPool in forum Pools, Pets and Creepy Critters
    Last Post: 07-23-2007, 11:18 PM
  5. Found my pool....
    By badkins in forum Above-Ground Pool Construction & Repair
    Last Post: 06-02-2006, 12:30 AM
