I recently found this forum and would like to submit my numbers to find out exactly what I need to do. I have been using the BBB method (per advice from a coworker) but I seem to be losing chlorine. I have a 20,000 gallon, vinyl pool. And I am confused......
My readings today (with a Walmart 6-way test kit) are:
FC: 1.3
CC: 1.3 (there was no change after waiting two minutes)
TC: 0 (I'm not sure I did this right)
PH: 7.6
ALK: 120
CYA: 90
I had been using Chlorine pucks with stabilizer from BJ's that the previous owner left but stopped using them a week ago because of my high CYA, and have only been using Clorox since.
Thanks for ANY and ALL ideas,
Janmo
. The numbers don't look bad, except for cl which needs to be 5 - 10 ppm (as per the best guess chart that is 'stickied' at the top of ths section). Add 2 gal of 5% bleach to the pool to bring it up to level. That should take care of things for your weekend - but remember to keep at least 5 ppm cl in the pool with your cya = 90. How easy is that? - just add 2 gal bleach and you're good to go. I'll assume you are hosting a pool party this weekend, so this is a quick and easy solution, if you want to lower the cya in the future, you can do so to reduce the chlorine you need to keep in the pool - but for now 2gal is all it will take today. Congrats on going with BBB and comming here to learn how to properly take care of your pool!! - Waste
