Results 1 to 3 of 3
Thread: what is a power ionizer?
    fog80 is offline Registered+ Thread Analyst fog80 0
    Columbia, Maryland, USA.
    Default what is a power ionizer?
    I see that the previous owner installed this power ionizer thing. It is displaying a temperature (that im not sure is accurate). There is a dial on the side that is set to 2 if i turn it any higher I get a red service light. 2 and lower gives me a green "active" light.
    any suggestions?
    waterbear's Avatar
    St. Augustine, Fl
    Exclamation
    Here is a link I found that gives some technical info.
    http://www.rhtubs.com/ion-technical.htm
    The active light means the unit is recieveing electrical power (don't they usualy call those things "on indicator lights?) and the red light means that the electrodes need to be replaced. The temperature is supposed to be accurate to within 4 deg if the pump is on and water is flowing through it.
    It is your basic copper/silver ionizer and for more info check the section of the forum on metals (this one is good, check popcorngirls post http://www.poolforum.com/pf2/showthread.php?t=91 ) and read Ben's FAQ!
    Best suggestion I can give you about it is to disconnect it and get it out of your system.
    Read the info on copper/silver in the metal section of the forum, especially Ben's FAQ! (I know I'm repeating myself but is IS important info!
    Default
    ok i think the previous owner used it at one time, but now its just a huge temperature display!
  1. SWCG and Unplugging the Copper Ionizer
    By RedwingT in forum Intex-type Pool Setup & Operations
    Last Post: 08-06-2012, 12:53 PM
  2. Liquid Ionizer/copper
    By drako4 in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-02-2010, 08:34 PM
  3. FlowTron Ionizer Instead of Pool Chems?
    By elsie in forum General Interest
    Last Post: 02-28-2008, 11:31 PM
  4. What should I do with the Copper Ionizer?
    By lora13 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-07-2006, 12:37 AM
