Thread: How much baking soda?
    Default Re: How much baking soda?
    My pool is a 20,000 gal AG vinyl liner.
    last night I tested with my HTH 6 way and got these numbers.
    TC 0.5
    Ph 7.2
    TA 120
    TH 500
    CYA >100
    I took some water in to the pool store for testing today and they got the following numbers.
    CYA 100
    TC 1.5
    FC 0.4
    Ph 7.1
    TA 86
    Adj TA 56
    TH 220
    Wtih your stabilizer that high the adjusted TA might be a more valid reading. CYA will test as part of the TA. When the CYA is in normal ranges it can pretty much be ignored but when it is as high as yours it shows as a large chunk of your TA. My advice would be to do a partial drain and refill and get your CYA down to about 30-50 ppm and then rebalance the water.
    duraleigh Guest
    Off the subject, but, regardless of who's numbers you trust, chlorine should be your priority right now...not Alk.
    If the pool store tested correctly, you need to shock your pool. I would move Cl up to 25-28ppm in a vinyl pool and 30+ if it's concrete.
    Then let it drift down into the 5-10ppm range and keep it there until you decide what to do about the high CYA.
  1. Baking soda - too much?
    By Stacyf419 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-14-2012, 08:10 AM
  2. Raising the pH of baking soda
    By dcombs44 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-08-2010, 09:40 PM
  3. How much baking soda can I add in a day?
    By mwsigler in forum Dealing with Alkalinity and Calcium
    Last Post: 06-16-2007, 08:45 AM
  4. Baking Soda How To Add
    By msb1766 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-20-2006, 09:39 AM
  5. pH--soda ash vs baking soda
    By bbluvbasket in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-13-2006, 01:23 PM
