Results 11 to 15 of 15
Thread: Is my pool/ AutoPilot setting OK?
    Sardian is offline ** No working email address ** Sardian 0
    Default Re: Is my pool/ AutoPilot setting OK?
    Using the Bleach Calculator program which offers a CYA calculation. For a 22000 gal pool it would take 3 pounds 8 ounces to raise the from 40 to 60.
    It's a handy little program, it can be downloaded here at the forum.
    Russell
    Quote Originally Posted by poolbee
    I see. Thanks. The more I understand, the fewer questions I'll have later on. I do know how to change the power level and will do so as soon as I get more CYA. I have an approx. 22,000 gallon pool. How much CYA do I need to add to increase it from 40 to 60?
    As always, thanks!
    Mesa, AZ
    I can't comment about your question on cell life, but one advantage of running at a lower power level and a higher percentage is that you have a finer resolution for adjusting output level. When you run high power and low %, each % change is a big change. Also, with the lower power level and higher %, you are adding chlorine more continuously, resulting in a slightly more stable chlorine level.
    NY
    Let me say that I really appreciate all the help on this forum.
    Tomorrow I will be adding the additional CYA to the pool and then lowering the power level to 1(and increasing the output), and testing from there to get my FC around 3 instead of 5.
    Central Texas
    Quote Originally Posted by Poolsean
    BETTER YET, I WOULD DROP THE CELL POWER FROM THE FACTORY SETTING OF 2 (6.5 AMPS) DOWN TO CELL POWER 1 (5.0 AMPS).
    Are these amps at 120 volts? They draw that high an electrical load?
    TW
    Saint Cloud, FL
    The volts are DC and usually in the 24 - 26 range.
    The 120 volts are applied to a transformer that then supplies the DC volts and amps to the control unit that supplies the DC volts and amps to the cell.
    The average load applied to the transformer on the DIG-220 controller, is about 200 watts.
    Hope this helps.
    Pat
  1. Setting up a pool soon and have questions
    By ohiosteve in forum Above-Ground Pool Construction & Repair
    Last Post: 04-06-2011, 10:57 AM
  2. Setting up the Easy Set Frame pool
    By Kimrst in forum Above-Ground Pool Construction & Repair
    Last Post: 04-04-2007, 09:29 PM
  3. Pool Pilot Setting
    By DONNIE in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 03-07-2007, 05:45 PM
  4. power setting on AutoPilot
    By brent.roberts in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-03-2006, 11:23 AM
  5. Setting pool returns and light recommendation
    By drumr in forum Above-Ground Pool Construction & Repair
    Last Post: 05-18-2006, 08:40 PM
