Since the water is being pumped through, it doesn't matter.
The only time it would matter is if you've got an airlock, at which point you would purge at the highest point with the feed at the lowest, but most times, air will work itself out of solar panels all on its own.
If you want to avoid digging things up, you could just switch the two tie ins near the pump on the exposed plumbing.
