Thread: Jack's Purple Stuff Questions
    Crowley, TX
    Default Re: Jack's Purple Stuff Questions
    An update with pool water test results.
    IG SWG; 20,000 gallons, Pebble Tec surface
    pH 7.4 (great)
    Alk 90
    Calcium Hard 325
    CYA 60 (maybe a little high)
    Salt Level 3.3
    Chlorine 5.0 (did not know chlorine would get that high with salt system)
    I guess the phosphate level is not prohibiting the generation of chlorine.
    Don't worry about the phosphates! Don't waste your money on phosphate removers! You don't have any algae...don't fix what ain't broke!
    SWGs can raise your FC levels very high if you let them....that is what the 'boost' or 'superchorinate' setting is for! (but it is better to shock with bleach...the boost setting will shorten your cell life)
    Crowley, TX
    I am now following your advice. I was just wanting to find the source of the phosphates. I am glad I did since I was the one putting them in the pool.
    Houston TX
    Question about the Jack's Purple Stuff...does it work to remove scale?? I'm looking for a good tile cleaner. Thanks.
    Quote Originally Posted by DogPaddle
    It's not really effetive on calcium at the pH it is used at. IMHO, The best thing to remove scale is muriatic acid and tile soap (for pools!) mixed together.
  1. Kem Tek 338 vs Jack's Magic Purple Stuff in salt pool?
    By JimK in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-29-2012, 01:15 AM
  2. Jacks Purple Stuff Alternative
    By Simmons99 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 09-01-2006, 12:58 AM
  3. Jacks Purple Stuff Alternative
    By Simmons99 in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-30-2006, 03:53 PM
  4. Jack's Magic Purple Stuff for SWG?
    By johndoe74 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-16-2006, 04:24 AM
  5. Jack's Magic Blue Stuff
    By EricH in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-15-2006, 04:27 PM
