Results 1 to 5 of 5
Thread: Testing for CYA
    psteward is offline ** No working email address ** psteward 0
    Omaha, Nebraska
    Default Testing for CYA
    I've been reading some posts on CYA, and getting some mixed messages about how high a level to try to run.
    I have a problem reading the test. One day it reads 40 another it's 50. I think the levels do not change that quickly so it must be the tester.
    Does anyone else have this problem? Does anyone have a recommendation?
    cwstnsko is offline Registered+ Thread Analyst cwstnsko 0
    Mesa, AZ
    Default Re: Testing for CYA
    Sounds like your level is about 40-50. That's probably accurate enough for you to understand the necessary chlorine levels to maintain.
    I've received several good tips here on getting more consistant CYA Test results.
    Assuming your already using a liquid test and not a test strip;
    Make sure the dot has disappeared completely when you take your reading. This is sometimes easiest to judge holding the tube at waist level outdoors, but out of the direct sunlight.
    I try to shake up the solution, let it sit a minute, shake it some more, let it sit (while I do other tests.) If you have any question about the reading, pour it back out of the tube into the bottle, and try again, no need for another water sample or more solution
    Omaha, Nebraska
    Thanks,
    I think the "out of direct sunlight" may be key for my problems. I've probably varied how I've done it, and I know it's been different on cloudy days.
    I'll be carefull about where I do it and see if I can get more consistant readings.
    I've been trying to get my CYA level up to 50 because I can't keep my FC level up without adding bleach every night. I think that a higher CYA level protects the FC. Is this true?
    PatL34 is offline Lifetime Member Widget Weaver PatL34 2 stars PatL34 2 stars
    Saint Cloud, FL
    You might want to check this thread, giving several ways to be consistent. It is a very subjective test.
    http://www.poolforum.com/pf2/showthread.php?t=1855
    Pat
    20,000 Gallon IG Diamond Brite pool, 1.5 HP Sta-Rite pump, Hayward Microclear DE3600 filter, Favco solar panels, Poolpilot DIG-220 with SC-48 cell.
    + SWCG OPERATION thread here: http://www.poolforum.com/pf2/showthread.php?t=1226
    + SWCG Running Costs post here: http://www.poolforum.com/pf2/showthread.php?t=316
    + Effective Stabilizer addition post here: http://www.poolforum.com/pf2/showthread.php?p=6645
    duraleigh Guest
    Good advice from cwstnsko. It gets easier with consistency.
    Yes, CYA protects Cl from the Sun....that's it's only purpose. The tradeoff is that the Cl is somewhat less effective with higher CYA levels so you must maintain a higher Cl range to compensate. No big deal, just maintain your Cl levels per the "best guess" chart (3-6ppm with CYA at 50ppm)
    You will still experience some Cl loss daily. Most pools seem to lose 1-3ppm.
  1. Cya testing
    By RedwingT in forum Pool Chemistry for Intex-type Pools
    Last Post: 09-14-2012, 07:00 AM
  2. testing, testing, 123
    By poolowner in forum General Interest
    Last Post: 06-07-2011, 12:21 PM
  3. Testing CYA
    By laughingboy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-07-2010, 09:34 PM
  4. testing help
    By haeffnkr in forum DPD-FAS based testing
    Last Post: 07-23-2008, 05:31 PM
  5. CYA testing
    By KirstenHW in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-22-2006, 08:28 PM
