Thread: How Much Muriatic Acid?
    Lincolnton, NC
    Default How Much Muriatic Acid?
    I have a 12x24 ig vinyl pool. approx 10,000 gallons. My PH is about 7.8-8.0.
    How much acid should I add to bring the PH down to an acceptable level?
    IL.
    Default Re: How Much Muriatic Acid?
    Do you have the bleach calc?
    If not, do a search for bleach calc, a most excellent program that is a valuable tool written by Michael Smith, a member here.
    With it you can easily calculate what you are asking, as well as a host of others that are equally valuable.
    Lincolnton, NC
    I do have the bleach calc. I did not even check to see if it did the muriatic acid calculations. I will when I get home from work.
    IL.
    You're Welcome
    It does lots of other stuff.
    Top right of the screen.
    To tide you over it's 8 oz for every .2 PH drop for 10,000 gallons of water.
    Quote Originally Posted by Rangeball
    More or less--a lot depends on the alk level. Just remember it's better to sneak up on your target (7.2-7.8), than to overshoot it.
  1. Lowering TA with Dry Acid Or Muriatic Acid
    By CelticDaddio in forum Dealing with Alkalinity and Calcium
    Last Post: 07-05-2007, 01:54 AM
  2. How much Muriatic Acid?
    By mccato in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-29-2006, 09:21 AM
  3. How to add muriatic acid
    By BullDean in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-12-2006, 11:51 PM
  4. how much muriatic acid
    By wolfcue in forum Dealing with Alkalinity and Calcium
    Last Post: 06-07-2006, 06:55 PM
  5. How much muriatic acid to add?
    By Blemished_Chemist in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-04-2006, 09:15 AM
