Results 1 to 10 of 29
Thread: So how come there aren't a LOT of sick people?
    Tennessee
    Default Re: So how come there aren't a LOT of sick people?
    Jo
    I do agree with you most of these illnesses are common in close order groups for example school and day care settings I was referring to environmental sources or infections of unknown origin. I should have been more specific about the source and epidemiology of the infection but I trying to keep as general as possible.
    I do agree that drowning is the greatest cause if disability and death from pools and the most preventable one.
    The dangers of DHMO once again!
    Tennessee
    Waterbear
    Think we will get mod slapped if we start this up again?
    It's not that SWGs are "different", it's that when running properly they have two advantages over other chlorination systems:
    1) They are constantly gen'ing chlorine at low levels. You don't actually need a lot of chlorine to keep your pool sanitary, but it has to be able to respond to demands on it--like people and suntan oils, etc. A residual level gives you a safe lee-way or metabolizing stuff will drop you below that sanitary level, leaving your water vulnerable to contamination. But an SWG takes over for that
    2) They super-chlorinate the water that passes through them, killing everything in it.
    Remember: SWGs ARE chlorine systems and follow chlorination rules. But rules of thumb may not be as applicable.
    Tredge is offline Registered+ Thread Analyst Tredge 0
    Wisconsin
    Quote Originally Posted by CarlD
    I've read the threads and the very informative PDF link on CYA....I'm trying to understand.
    If SWG's constantly generate new chlorine then there should be less need for CYA not more!
    They way I understand it CYA acts as a time release but the tradeoff is that the chlorine isnt as "active". I understand the value of that tradeoff if I were adding chlorine once a day but a SWG adds all day and night.
    I also understand that a SWG superchlorinates at the cell and in the pipes...but high CYA has nothing to do with chlorine in the pipes, its intended for keeping chlorine in the pool longer (Protection from sunlight esp)
    I'm sure SWG's opperate safely at these CYA levels...I guess I just cant get my mind around the science behind it.
    Some people have hobbies.....I have a pool.
    Central Texas
    The part of that PDF article that got my interest is this chart:
    He suggests that 5-12ppm is good for an automated pool, no more than 20ppm for a manually managed pool.
    Saint Cloud, FL
    Quote Originally Posted by Tredge
    Actually you need more! The cell instantaneously generates a high concentration of chlorine that destroys the chloramines AT the cell.
    If there was not a high CYA level, most of it would be used up before it got into the pool proper. The alternative would be to run at high chlorinating outputs, resulting in rapid reduction of cell life.
    Hope this helps.
    Pat
    IL.
    Tredge, I don't get the feel that SWG owners are operating their units 24/7, and as such need the CYA to keep the residual when the unit's off.
    bbb is offline Registered+ Thread Analyst bbb 0
    Quote Originally Posted by PatL34
    Hope this helps.
    Pat
    :lightbulb lighting over head:
    Thanks, Pat. This is about the 10th time I read that if there was not a high CYA level, most of the SWG-produced chlorine in the cell would be used up before it got into the pool proper - and I finally figured it out -
    Without the added CYA, the superchlorination at the cell is TOO effective, so, under higher bather load or organic contaminant conditions, there isn't much unused FC left after the water passes the cell and goes toward your return!
    With additional CYA present (say 60-80 ppm), there is a little less superchlorination at the cell (because chlorine is less effective per PPM with CYA present), so there is more residual left as the chlorine passes back into the water into your pool, where it can fight contamination of the water actually in the pool and (keeping this sort of on topic), preventing people from getting sick from stuff in the pool!
    Finally, because there is still effective (just a little less powerful per PPM because of the 60-80 ppm CYA) superchlorination going on in your water because the salt water generator cell is operating, you should be able to run with a (slightly) lower amount of FC residual in your SWG pool than with a pool chlorinated in batch form (like bleach or cal-hypo) or drip form (chlorine feeders, trichlor pucks) for your given level of CYA.
    ps - the "benefactor or bomb" article is very good but needs to be taken with a grain of salt (whether or not you are running a SWG! ) PoolDoc has excellent comments elsewhere on the forum about it - here is the link. CYA is NOT "bad" -- running your pool with too much of it and not enough chlorine (like anyone using a constant amount of trichlor pucks in a feeder all year, and using a test kit or strip that only counts to 5 or 10ppm of chlorine) IS "bad". It's that simple. And for people who have very sunny pools (aylad comes to mind), CYA is a huge help. My pool isn't that sunny, but when I cholorinated exclusively with bleach last year, I chose a higher CYA rate so I could add bleach every other day instead of every day. And now that I have an SWG, I am slowly increasing my CYA from 35 to (probably) around 60.
    My understanding: with the addition of common sense and real-world experience to the "benefactor or bomb" material, you get Ben's "Best Guess" chart.
    bbb = bleach, borax, & baking soda
  1. Hello Pool People
    By Cloud26 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-27-2011, 10:55 PM
  2. Help with 6 port valve - no PSI - pop up filters aren't working
    By bortoldr in forum Pool Equipment & Operations
    Last Post: 11-11-2010, 01:02 AM
  3. Help! I'm sick of vacuuming.
    By shadowman in forum Pool Equipment & Operations
    Last Post: 06-13-2007, 11:41 PM
  4. My Dolphin is sick!
    By jdolby in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-25-2006, 10:29 PM
  5. Ok people - I'm on my own - HELP!!!!!!!!!!!!
    By Gracy101 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-01-2006, 07:05 PM
