Results 1 to 10 of 12
Thread: Borax
    fcfrey is offline ** No working email address ** Thread Analyst fcfrey 0
    Central PA USA
    Default Borax
    Easing into the BBB method of doing things.
    Cl=2ppm
    TA=120
    CYA=40
    Temp 82F
    pH is 7.0 after 5.75 inches of acid rain. Every thing else is in specs. How many mules do I throw into the pool?
    Default Re: Borax
    Start with about 1/2 box, add slowly through skimmer breaking up clumps, give it a couple hours to circulate, then test--and add more as needed. You're looking for the 7.2-7.6 range.
    Default Re: Borax
    Quote Originally Posted by fcfrey
    Thanks for the morning chuckle! What a GREAT visual image! "Hee-Haw, Hee-Haw!"
    Houston TX
    Default Re: Borax
    Quote Originally Posted by aylad
    Not to be a PITA, but what size box? Is this the "grocery store standard size" or the "Sam's Warehouse Club" box? Can you give your recommendation in cups or something? Thanks!!
    Default Re: Borax
    Yeah, Watermom's right, as usual. Sorry, I rarely have to use it, so I only get the grocery store box.
    Central PA USA
    Default Re: Borax
    Thanks to all --- Glad I could add a bit of humor for all. Next step will be Bleach --- downloaded the calculator. Problem is I have lots of pucks and Cal Hypo left.
    May try a liquid shock today -- smelling the chloromines just a bit, soooo.... Do need to add OTO to my DPH kit so I can look at the higher CL Levels.
    Default Re: Borax
    If your calcium level isn't too high (more than 200 or so for a vinyl pool, then you can still use the cal-hypo to shock if you want to--you just don't want to let it get high enough to start precipitating out of the water. Tightly cap your trichlor picks, and you can use them at the beginning of next season when you're trying to raise your CYA again.
    Central PA USA
    Default Re: Borax
    OK --- that sounds reasonable --- Perhaps I should start another thread for this question.
    I have never seen a difference when I test for total chlorine. Using a DPD test kit --- Fresh reagents and careful attention to procedure. Free chlorine now is between 2 & 3 when I add the 5 drops of R0003 nothing changes. We shock regularly (once per month) and I really don't want to see any combined chlorine but I would think I should see something. Perhaps I shock too often??
  1. pH between 6.8 and 7.2 (ish)... how much Borax?
    By mastamoon in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-21-2012, 04:33 PM
  2. How much borax
    By lstinthot in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-15-2011, 02:50 AM
  3. Borax
    By roytyson in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-11-2006, 12:22 PM
  4. How much borax?
    By Rangeball in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-07-2006, 06:17 PM
