Hi, You should have a good 12 - 24 inches of level ground around you pool. This is very important on the low side. There are many ways to fill and pack a low area but sand is not one of them. Sand should be used under the liner only. Not under the pool frame.
Digging down to the lowest spot is the best option but not always the most feasable. The pool just needs a firm level base with plenty of ledge around it. Best of luck, Dennis
