Results 1 to 10 of 14
Thread: Mustard alge??
    conductor500 is offline ** No working email address ** conductor500 0
    ky
    Default Re: Mustard alge??
    Ok, pool water to 10 ml line, added scoop of powder, dropped 1 drop 23x to clear red color added 5 drops #3 solution and color remained clear. Checked it 2 times readings were the same.
    Does that mean:
    FC 11.5
    CC 0
    TC 11.5
    Do these #'s look right??
    Oh, my PH. is at 8.6
    what could have raised this from 7.4? All I added is bleach to shock levels
    Sun Prairie, WI
    Quote Originally Posted by conductor500
    Does that mean:
    FC 11.5
    CC 0
    TC 11.5
    Those numbers look correct.
    I can't answer about the pH, but I am sure someone will come along and help with that.
    ~Dr. Spike
    Pool: IG vinyl, heated, fully enclosed (dome)
    Shape: Grecian (rectangular)
    Size: 20'W x 40'L
    Depth: 4' / 8'
    Filter: Sand w/DE added
    Other: 6' Diving Board
    Maintenance: BBB! Ben's PS234 kit! Manual vacuum, brush, and Pool Buster Max CG Gold
    You did the test correctly and your numbers look just fine. Although bleach does raise ph in some pools, (never does in mine, however), I can't imagine that it would have caused that much of an increase in ph. Maybe testing error one of the times it was tested. Test the ph one more time, and if it is that high, add some muriatic acid to lower it back down to 7.4-7.6..
    South Central PA
    Is it conceivable that I could purchase just the 3 chemicals mentioned to test the high levels of chlorine (R-0003, R-0870 and R-0871)? I have ordered Ben's kit, but could use some help in determing high chlorine levels now.
    IG 30,000 gal vinyl
  1. Mustard Algae
    By AndreaA in forum Dealing with Algae & Slime
    Last Post: 06-11-2011, 11:18 AM
  2. Mustard Algae
    By rwhitsel in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-01-2011, 11:56 AM
  3. Wanted: Mustard algae or suspected mustard algae
    Last Post: 08-30-2007, 08:40 PM
  4. Had alge now cloudy
    By pilot in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-11-2007, 08:34 AM
  5. Mustard Algae???
    By Jaybird70 in forum Dealing with Algae & Slime
    Last Post: 11-03-2006, 10:20 PM
