Results 1 to 10 of 14
Thread: Mustard alge??
    conductor500 is offline ** No working email address ** conductor500 0
    ky
    Default Re: Mustard alge??
    I bought the PS234. Is there another one with higher CH. readings?
    The PS234 will go much higher. You should have a vial with some powder called R-0870. (Unless the number changed on the new kit, which I don't think it did. It may also be labeled as DPD powder.) You fill one of the collection bottles to the 10 ml mark and then add a scoop of the powder. If that doesn't turn the sample pink, you can add another scoop. Swirl to mix (don't worry if every bit of it doesn't dissolve completely) and then slowly add one drop at a time of R-0871 (FAS-DPD reagent), swirling after each drop. Count the number of drops it takes to turn the sample clear and then multiply the number of drops by 0.5. (Ex. 6 drops x 0.5 = FC reading of 3 ppm.) Then, to test for CC, add 5 drops of R-003 to the sample. If it stays clear, you have no CC. If it turns pink, you again add one drop at a time of R-0871 until it turns clear again and then multiply the number of drops by 0.5. That will be your CC reading. TC = FC + CC. This chlorine test can go way higher than 5. Hope this helps.
    EDIT: I'm assuming that the PS234 also comes with the quick OTO chlorine test where you use the testblock that goes to 5. That must be why you thought the kit only went to 5. With the DPD/FAS test described above, you don't use this little test block.
    ky
    Thanks watermom,
    I just completed my first test with the PS234 and I did use the FAS DPD test although I thought it was just testing cc and fc. I had to dillute with 5parts distilled water to 1 part pool water because my pool sample was almost red and I lost count of drops I put in the sample with no color change so here are my readings. Let me know if this seems right.
    CL. 10 OTO test wit 5ppm dis. water and 1ppm pool water
    FC. 7 used same dillution as above
    CC. ? when dillution method was used only added 1 drop to clear water
    PH. 8.2
    CYA 70 Really like thie bigger tube can see better.
    now these readings are 2 days after keeping my pool at shock level around 15-20 for about 3 days to clear a alge bloom
    I think I have done these tests right but not sure.
    Thanks agin for the help
    How do I register my kit to get into the other part on this site?
    The DPD/FAS test does just test FC and CC, but if you add those two numbers together, you get your TC reading. I'm still a little confused about what you did, though. You do not need to dilute the sample when doing the DPD/FAS test. Just take a 10 ml sample of pool water, add a scoop of DPD powder, swirl and then add drops of R-0871 one at a time, swirling after each one. When the sample turns clear, multiply the number of drops by 0.5 and that is your FC reading. To check for CC, take the same sample (not a new one) and add 5 drops of R-003 and swirl. Then, add more drops of R-0871 one at a time, swirling after each. Multiply the number of drops by 0.5. That is your CC reading. Add the FC and the CC readings to get your TC reading. I hope this will clarify for you how to do the test.
    Retest without diluting the sample and then repost your readings and somebody here can help you.
    ky
    Ok, pool water to 10 ml line, added scoop of powder, dropped 1 drop 23x to clear red color added 5 drops #3 solution and color remained clear. Checked it 2 times readings were the same.
    Does that mean:
    FC 11.5
    CC 0
    TC 11.5
    Do these #'s look right??
    Oh, my PH. is at 8.6
    what could have raised this from 7.4? All I added is bleach to shock levels
    Sun Prairie, WI
    Quote Originally Posted by conductor500
    Does that mean:
    FC 11.5
    CC 0
    TC 11.5
    Those numbers look correct.
    I can't answer about the pH, but I am sure someone will come along and help with that.
    ~Dr. Spike
    Pool: IG vinyl, heated, fully enclosed (dome)
    Shape: Grecian (rectangular)
    Size: 20'W x 40'L
    Depth: 4' / 8'
    Filter: Sand w/DE added
    Other: 6' Diving Board
    Maintenance: BBB! Ben's PS234 kit! Manual vacuum, brush, and Pool Buster Max CG Gold
  1. Mustard Algae
    By AndreaA in forum Dealing with Algae & Slime
    Last Post: 06-11-2011, 11:18 AM
  2. Mustard Algae
    By rwhitsel in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-01-2011, 11:56 AM
  3. Wanted: Mustard algae or suspected mustard algae
    Last Post: 08-30-2007, 08:40 PM
  4. Had alge now cloudy
    By pilot in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-11-2007, 08:34 AM
  5. Mustard Algae???
    By Jaybird70 in forum Dealing with Algae & Slime
    Last Post: 11-03-2006, 10:20 PM
