Can I use a Hayward above ground pool pump (or any pump for that matter) with my 18' metal frame pool (6,780 gallons)? The Hayward website says not to use their pumps on these "storable pools", yet I can't figure out why.
I mounted my solar panels (2 2x20) on a fence this year, and the pump that it came with won't push the water through (don't know HP, but it says it pumps 2,000 gallons an hour....help Carl???)
So I'd like to get a better pump, but not sure what to use. Do standard above ground pool pumps plug into a normal 110 GFI outlet? What about grounding to the pool frame or copper wire like the manual suggests? I'd like to keep it simple as possilbe (meaning myself...not an electrician), for we're moving in a few years and will get a real pool then.
Thanks and help!!!
