Results 1 to 10 of 17
Thread: newbie. Our first pool, Need info on sand filter
    rnjng Guest
    Question newbie. Our first pool, Need info on sand filter
    We bought a house that has a 24'X48" above ground pool. First off, has anyone heard of columbia sand filters? None of the pool supply stores in my area deal with this manf. What should the pressure of the filter be at normal circulation. What is normal maintenance for this type of filter. Can I run this type of filter 24/7 to clear up cloudy water????
    duraleigh Guest
    Default Re: newbie. Our first pool, Need info on sand filter
    Depends on your pool. Most systems run in the range of 10-22psi
    Usually nothing except an occasional backwash.
    You can run it 24/7 but it probably won't clear your pool....You've probably got some chemistry issues causing the cloudiness. To keep us all from just guessing, post a complete set of test results for:
    FC
    CC
    pH
    Alk
    CYA
    With those results, you'll get lot's of solid advice on clearing your pool.
    rnjng Guest
    thanks fo the response, like i said this is our first pool, terminology is minimal. I bought a test kit that tests for Cl and Ph. the Ph did not change it remaind clear. the Cl was at the lowest color on the chart. So none the less, it needs chem. obviously. I'm not sure what you mean by test FC, Alk, CYA. what kind of test kit do I need?
    duraleigh Guest
    FC-Free Chlorine
    CC-combined chloramines
    Alk-Alalinity
    CYA-Cyanuric acid or stabilizer
    My first step would be to take a sample to a pool store that will test those things for you and post back your results.
    Secondly, read everything you can on the forum...particulary ALL the stickies at the top of the Chlorine forum and Pool Chemistry forum. It'll answer many questions and create many more.
    Post back with those test results and we'll all help get your water cleared up.
    rnjng Guest
    Had water tested they said ph is vry low and to add 1 1/2 pounds of soda ash Before anthing else. What do you think???
    duraleigh Guest
    We would need numbered test results to offer good advice, otherwise, we're simply taking wild guesses.
    rnjng Guest
    The girl who tested the water was new or something, she said that the water just turned "pink?". I guess there was no color to match that on the chart??? So she asked someone what I should do, cause she had not seen that result before. So the advice was 1 1/2 soda ash.
    Go to Walmart and buy the 5-way drops based kit they sell for around $13 and then test your water yourself and post your results. We really need some numbers to be able to help. While you are at Walmart, buy some 20 Mule Team Borax which you can find in the laundry detergent aisle. We prefer to use that to raise ph instead of soda ash. Also, pick up several jugs of plain, unscented bleach. Generic Walmart Ultra brand is fine.
    rnjng Guest
    I have a 2way test kit test cl and ph, ph was yellow, so lower than 6.8 . Cl stayed clear.
    If your ph is below 6.8, that is a very big concern. Get some Borax and add a half a box slowly to the skimmer while the pump is running. Then let it circulate for 3 or 4 hours, then retest ph, and add more Borax until you get it to 7.4-7.6. Also, add 6 quarts (1.5 gallons) of plain, unscented bleach to the skimmer - again while the pump is running. It is OK to add the bleach right after you add the Borax.
    That is just a start. We really need more testing results to really be able to help with your problem. Get a better test kit. At the very least, the 5-way test kit from Walmart. We need more than just ph and cl readings to be able to help you much.
  1. Newbie.... looking for pool info... Doughboy pools?
    By unh044 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-11-2012, 06:42 PM
  2. Newbie needs info on filter
    By szcakes in forum Pool Equipment & Operations
    Last Post: 08-01-2006, 04:21 PM
  3. pool newbie with new sand filter questtions
    By rnjng in forum In-Ground Pool Construction and Repair
    Last Post: 07-21-2006, 08:14 AM
  4. Newbie pump/sand filter AIR question
    By famdog in forum Pool Equipment & Operations
    Last Post: 06-01-2006, 09:20 AM
