Results 1 to 4 of 4
Thread: Chlorine loss
    Default Chlorine loss
    what's an average daily chlorine loss?
    I'm losing 2-3ppm daily.
    Is this normal?
    the pool is in full sun and we are having extremely high temps here in So Cal right now (triple digits today)
    Di
    Pool details: 10,000 gallon inground concrete pool; Full California Sun! DE filtered
    Default Re: Chlorine loss
    You'll need to post your numbers here. What's your CYA level?
    mas985's Avatar
    mas985 is offline Lifetime Member Whizbang Spinner mas985 3 stars mas985 3 stars mas985 3 stars
    Pleasanton, CA
    When my CYA was 30, I know I was losing 2 ppm a day since I was putting in 2 ppm/day and the CL was staying at 2 ppm. I just upped my CYA so I'll have to see how it goes.
    Mark
    CYA is 50
    Di
  1. How much chlorine loss is normal?
    By dubbedout in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-02-2013, 08:51 PM
  2. Average daily chlorine loss and CYA
    By jwhouse in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-04-2012, 06:02 PM
  3. Higher chlorine loss than last year
    By dancu in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 10-02-2007, 10:52 AM
  4. How Much Chlorine loss Is Normal
    By DCR in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-21-2006, 08:25 PM
