Results 11 to 12 of 12
Thread: What are the Perfect Numbers?
    Default Re: What are the Perfect Numbers?
    Quote Originally Posted by CarlD
    It was '42' I thought.
    I think you're right...been years since I read it...they say the memory is the second thing to go
    When I was a kid, perfect numbers were 36-24-36...
    They still are!
    Actually Waste goofed on CC:
    Sure, .05ppm is OK, but you can't read that. Usually, you can only see that it's .5 ppm or less. If you use the 25ml line, you can measure CC down to .2ppm
    Once again Carl is right!
    Talking Re: What are the Perfect Numbers?
    Jeeze Carl, I was quoting you almost verbatum, you gotta go and complain about a simple order of magnitude??
  1. Clear but not perfect - yet.
    By mwoolfso in forum --cleanup--
    Last Post: 06-09-2013, 05:52 PM
  2. Perfect Pool Problems???
    By KPalom in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-27-2011, 09:01 PM
  3. The Perfect Storm
    By janmo in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-17-2007, 12:38 PM
  4. The perfect test
    By milynor in forum DPD-FAS based testing
    Last Post: 05-15-2006, 08:01 PM
  5. Gladon Perfect Pool Bottom
    By ToddLV in forum Above-Ground Pool Construction & Repair
    Last Post: 05-11-2006, 09:32 AM
