Quote Originally Posted by adl6009
I knew there had to be a few informed opinions out there somewhere
I am leaning towards the safety mesh cover because 1. They look nice and clean in the backyards I have seen them in. 2. They are supposed to provide a layer of safety against accidental or unauthorized entry. 3. I have been told they are easyto put on and take off.
I am worried about them because of the overflow potential. Do you have to pump out the pool thru the winter? I guess the water in the skimmer isn't a big deal as my skimmers as yet haven't been destroyed. Will the thing I screw into the skimmer port protect a skimmer FULL of water??
I am glad Tredge said he installed his own, I am kinda on a do it myself kick right now.
We have an Anchor Industries mesh cover for our 23x41 kidney-shaped. It looks very good (straps are on the underside) and is relatively light and easy to put on / take off (but still a 2-person job). Quite a bit of junk falls through over the winter (Eastern PA, lots of trees around) but one thorough spring vacuum takes care of it. Overflow has not been a problem because I leave the cleaner line (which comes out slightly below the tile line) open and it acts as a drain to the woods behind. If I can, I try to brush a heavy snow off the cover; otherwise it pulls the cover down to the water until everything thaws, but so far no damage (have had the cover for 6 years). I always put something crushable in the skimmer and have not had a problem in 15 years (knock on wood).
We considered but rejected the solid "safety" cover (also Anchor), which comes either with a mesh panel in the center or with a pump that sits at the low spot on the cover. Besides being much heavier (harder to handle) and somewhat more expensive than mesh, I didn't like the idea of all the debris piling up right under the mesh panel (although that might be okay) or having to remove the pump during freezing conditions (according to the instructions). If it weren't for that freezing problem, I think the solid cover with a pump would be ideal for my conditions. Mesh is certainly ideal for warmer, tree-free conditions.
