Results 1 to 8 of 8
Thread: What is correct way to add acid to pool?
    Default Re: What is correct way to add acid to pool?
    It will not raise the salt level...it will maintain it. When the salt water generator generates chlorine it breaks down the salt into chlorine and sodium hydroxide (lye). This is what causes the pH to rise. When you add muriatic acid (HCl) it neutralizes the lye and reforms the salt and also forms water. If you use dry acid this does not occur and you will be creating sufates in the water which can cause problems if they build up too high.
    Why do you want to lower your salt levels....3200 ppm is perfect as far as most manufacturers of SWGs say. Lowering the salt concentration will cause the cell to have to work harder to generate chlorine and will shorten it's useful life! I actually run my salt levels closer to 3400 ppm for this very reason. In terms of cell life it is better to run the salt a bit higher than lower! The cell is not a cheap item to have to replace!
    NY
    I would like to try my salt at around 3000. That is what is recommended. I will be bringing my water to my pool builder this week for testing. Ben's salt test is giving me a reading of 3200 but my Autopilot is telling me 3700. My water has a very definite salty taste-much saltier that the water we tasted at the builders. I suspect the Autopilot is closer to the accurate number because the purifier is almost always off and when it is on I can run it at 15-20 but my chlorine levels run at 5/5.5 and my CYA reads in the low mid 40's.My cell is on level 2. Someone suggested I lower it to lever 1 and raise the output? Right now my numbers are all very good so would you suggest this? These are my numbers after adding the muriatic acid yesterday:
    FC 5
    CC 0
    pH 7.4
    ALK 110
    CYA 45
    temp 84
    I only tested Cal once in the beginning because I have a liner pool. It was 170.
    So if I am understanding, and as I said, chemistry isn't my forte, The SWG can run so low because the salt is high? Temps have been steady at about 83-84. I just think the salt taste is too strong. I though it was supposed to be slight.
    First thing I would do is bump up the cya to the recommended 60-80 ppm. From everything that I have been able to find out (and from what I have seen in my own pool and in the water testing histories of my customers with SWGs the higher cya levels do make a difference because of the way the chlorine is introduced into the pool with a SWG as compared to manual chlorination. I would have the salt level checked at a pool store or with an Aquacheck salt test strip (they actually are pretty accurate!) and see what readings you get. It is possible that the PoolPilot is off calibration and can be recalibrated to a known accurate salt reading. As far as the adjustments, I am not that familiar with the with the Poolpilot settings but perhaps PoolSean will chip in and get you straightened out! You might want to start in thread in the Chlorine Feeders and Salt Generators section asking how to set the unit up. I know he monitors that one!
    NY
    Thanks Waterbear for all your help and information. I am planning to get the water testing tomorrow. The way my water is now is how the pool co. set it up. I have only added acid.
    Thanks again.
  1. Is this a correct pump to use for a above ground swimming pool
    By qbinflorida in forum Intex-type Pool Setup & Operations
    Last Post: 06-09-2012, 11:38 AM
  2. Correct way to repair pool plaster
    By Cberry in forum In-Ground Pool Construction and Repair
    Last Post: 03-27-2011, 03:50 PM
  3. What Are the Correct Numbers For a SWG Pool?
    By jaypool in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-13-2007, 11:54 PM
  4. Vinyl Pool Covers... Are my assessments correct?
    By JWB in forum Pool Equipment & Operations
    Last Post: 03-13-2007, 07:56 PM
