Re: Pool still green
					Just curious, what is your TC as tested with an OTO test (liquid turns yellow, usually found in cheapie 2 way drop based  chlorine/ph testers).  the results might give some enlightening info as to what is happening. I assume you are testing with strips since you gave a TA of 80 and that is one of the graduations on the strip and you also gave numbers for Total hardness which is what strips test for.  Drop based kits test for calcium hardness which is a bit different.
