There are other folks here with lots more experience than I, who can be of better help but one thing you really need to do is get more accurate test result numbers. CYA from 50-100 is too wide a range to know what your proper Chlorine level should be. Also, you need to know your CL level ~ how much above 10ppm? Everyone here recommends using a better testing method than test strips. If you don't have a good kit, you can take a water sample to a reliable pool supply store and have the water tested for you.
One thing you can do is feel the stuff settling in your pool and see if it's gritty or slimy. That will help you to determine if it's dirt or algae. I'm sure someone else will chime in with some good advice for you.
