Thread: air in my lines
    Oklahoma city, Oklahoma, USA.
    Default air in my lines
    I dont know if i have to strong of a pump 1 1/2 hp and a 150 lb sand filter. I change my pump motor from a 1 hp and to a 1 1/2 and now i have air in the lines when i hook up my vacuum line or my baricuda automatic cleaner. I have tighten the lines up and still get air in when i plug up the hose. is it posible to hae to strong of a motor.
    Kurt Bourn
    24' round 12,000 gal
    Oklahoma City
    duraleigh Guest
    Default Re: air in my lines
    Not only possible but sounds like you have one. There's a multitude of causes for air in the lines but your pump sounds wa-a-ay too big. The pump curve should be in your pump documentation. The gpm from your pump should not exceed your filters gpm capability.
    My 1.5hp pump produces 110 gpm in my pool but my filter is capable of 140gpm...it has 950 lbs of sand.
  1. Blow out lines
    By ImpalaRob in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 08-24-2012, 06:44 PM
  2. blowing out lines
    By pq1747 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-08-2010, 10:05 PM
  3. How to get antifreeze into lines
    By handy1 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-08-2009, 02:31 PM
  4. Air in Lines
    By VickieC24 in forum In-Ground Pool Construction and Repair
    Last Post: 08-22-2008, 07:02 PM
  5. Air in lines
    By VOLDADDY in forum Pool Equipment & Operations
    Last Post: 05-05-2006, 07:35 PM
