Just got my new test kit and tried it out. Here are my findings:
FC 5
CC .5
TC 3-6
You used the FAS-DPD test and the test in the PS-200. They aren't compatible and your TC number can be more accurately computed by adding FC and CC to get a TC of 6ppm. This means you should shock your pool to clear the CC. Raise FC to 12ppm and see after a few hours if that does it.
pH 7.2
Tad low, but an ig concrete pool should push it up. Still, with your Alk, you should use aeration to raise pH, and nothing else for now.
Alk 250
Whoa! Way too high! You'll need to lower pH to 6.9 and aerate the water to raise it again. See the Lowering Alk section
Cal 210
Cya 20
Temp 78
Salt 600
these all look good, but you may want CYA at 30 instead.
Have a IG 18X36 concrete pool. Two speed pump with a sand filter. What should my reading be?, and are my figures O.K. The water is very clear and the pool looks great! Thanks for all you people do. I think I am starting to understand all this stuff. Something must be clicking because my pool never looked this good last year!
