Results 1 to 3 of 3
Thread: New kit
    Smile New kit
    Just got my new test kit and tried it out. Here are my findings:
    FC 5
    CC .5
    TC 3-6
    pH 7.2
    Alk 250
    Cal 210
    Cya 20
    Temp 78
    Salt 600
    Have a IG 18X36 concrete pool. Two speed pump with a sand filter. What should my reading be?, and are my figures O.K. The water is very clear and the pool looks great! Thanks for all you people do. I think I am starting to understand all this stuff. Something must be clicking because my pool never looked this good last year!
    Default Re: New kit
    Quote Originally Posted by bjdrogo
    FC 5
    CC .5
    TC 3-6
    You used the FAS-DPD test and the test in the PS-200. They aren't compatible and your TC number can be more accurately computed by adding FC and CC to get a TC of 6ppm. This means you should shock your pool to clear the CC. Raise FC to 12ppm and see after a few hours if that does it.
    pH 7.2
    Tad low, but an ig concrete pool should push it up. Still, with your Alk, you should use aeration to raise pH, and nothing else for now.
    Alk 250
    Whoa! Way too high! You'll need to lower pH to 6.9 and aerate the water to raise it again. See the Lowering Alk section
    Cal 210
    Cya 20
    Temp 78
    Salt 600
    these all look good, but you may want CYA at 30 instead.
    There's no set pressure
    mbar's Avatar
    mbar is offline Lifetime Member Whizbang Spinner mbar 3 stars mbar 3 stars mbar 3 stars mbar 3 stars
    Ashland, PA
    Default Re: New kit
    With the dpd test, after the powder, you put in #2. The amount of drops divided by 2 is your free chlorine. Add the 5 drops of #3, the drops divided by 2 is your combined chlorine. Add these together and this is your free chlorine. So if you got 5 fc, and .5 cc, then your tc should be 5.5 which is good for cya of 20
    .5 of cc is ok, but no higher, and 0 is better
    Your ph is ok, but could be 7.4 - 7.6
    Your alk is high - it should be 80 to 125
    Your calcium is good, chould be 200 - 400
    Your cya is low, which is ok, but you may use your chlorine up fast on a sunny day. You can look in the chlorine section of the forum and look for the "best guess chart" it will show you where your chlorine needs to be with cya.
    Northeast PA
    16'x32' kidney 16K gal IG fiberglass pool; Bleach; Hayward 200lb sand filter; Hayward pump; 24hrs; Pf200; well; summer: none; winter: mesh; ; PF:7.5
