Results 1 to 10 of 16
Thread: This may be a siily question but.......
    no1ford is offline ** No working email address ** Thread Analyst no1ford 0
    Default This may be a siily question but.......
    I just have to get an "OK" on it! I have had metal problems in my water since day one. Iron. I had used a product called iron out or something and it worked great! I recently had 1/4 of the pool drained due to vaccuuming to waste and now the water after refill has a green hue to it again! I wil have to use more iron out when more new water added, right?
    And on the BBB system- do you ever shock without bringing chlorine up high, Like with a blast or anything? For example, after swimmers.
    mbar's Avatar
    Ashland, PA
    Default Re: This may be a siily question but.......
    Yes, everytime you add a lot of water, you need to add more sequesterant. I only shock with bleach, but when I do I make sure my ph is no higher than 7.2 - 7.4, and that there is sequesterant in the water. I do run my chlorine to the high level when there have been a lot of little kids in the water, or a heavy rain. If you have enough sequesterant in the water, you can shock any time you want, but it isn't necessary unless you have combined chlorine, or the pool looks cloudy.
    Northeast PA
    Ok-I just needed a little clarification! I am just fiishing up getting all of the floc I used out of my pool! Water is looking much better now. A few places left to vaccuum and hopefully this month long battle will be won! Thank you for helping-I am sure this will not be the last question I have!
    Already thought of one! I have approx. 7600 gallon pool. My iron remover covers 5000. I used only half of the bottle as I only refiilled 1/4 of the pool. It still loks a little green-if I use the rest will it do any damage?
    mbar's Avatar
    Ashland, PA
    You can put the rest of the bottle in the water, it won't hurt anything. I would rather have too much than not enough.
    Northeast PA
    Today after seroius rain last night- my numbers are a liitle whacked
    TC-2-4
    PH- 7.2
    Alk-210
    Cya-30
    If I add Ph minus to lower Alk-then my Ph will drop too low. I do not quite understand the lower Alk sticky. Any advice. Water clear-no sparkle
    Quote Originally Posted by no1ford
    TC-2-4
    PH- 7.2
    Alk-210
    Cya-30
    If your pool is plaster or fiberglass drop the pH to 7.0 and start aerating. If it is vinyl then 7.2 is the right pH to start aerating. As you aerate the pH will go up and the Alk will go down. Keeep adding acid as you aerate to keep the pH at the target (7.0 or 7.2) until your ALK reading is around 100-120 ppm then stop adding acid and aerate until your pH is about 7.4....Your Alk should then be fine. (If you have a vinyl pool then you really only have to get the ALK down to about 140 ppm.)
  1. Spring Vacuum Question and Liner Question
    By DougM in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-22-2011, 12:11 AM
