Thread: Initial cost of an SWG?
    Mesa, AZ
    Default Re: Initial cost of an SWG?
    IIRC, when I had my pool built, the credit for deleting the feeder was about $200 and the SWG was about $1000-$1200. I expect the actual cost of the feeder was a little more, but they would only credit me $200 to drop it from the package.
    mas985's Avatar
    Pleasanton, CA
    This might not apply to you but my incremental cost for a SWCG was only $400. That is because I chose the AquaLogic system controller for my pool and I only had to buy the cell which was $400. The controller was about $900 at the time.
    Mark
  1. Initial setup
    By dkdevo in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-29-2013, 05:47 PM
  2. first water test after initial treatment
    By happysongbird in forum --cleanup--
    Last Post: 11-05-2012, 03:57 PM
  3. In Ground Pool Cost - Which Cost the Most?
    By webfeet in forum In-Ground Pool Construction and Repair
    Last Post: 08-04-2006, 04:31 PM
  4. Initial Steps
    By snapperbig in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-28-2006, 08:29 AM
  5. initial test results
    By p.p.h. in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-11-2006, 12:12 PM
