Thread: Another . . .new PS234 results on "new" pool
    JonnyG is offline Registered+ Thread Analyst JonnyG 0
    Default Another . . .new PS234 results on "new" pool
    New plaster IG pool here. Just got my kit yesterday and everythin glooks pretty good -
    FC - 3.0
    CC - 0.0
    TC - 3.0
    PH = 7.7 (less than 7.8 but higher than 7.5)
    ALK = 100
    CAL = 210
    CYA = 30
    Temp = 84
    SALT = 4600
    I expected similar results based on the fill water and what I have been doing over the past few weeks. Although, I am surprised that the CYA is not higher as I added 12 #'s CYA since I filled the pool (over past 4 weeks). Based on the Calculator my CYA should be around the 50 CYA recommended by the SWG company.
    Q1 - The SWG manual says the minimum CYA is 50 for operation (I would rather stay lower, should I stay with what the SWG company reco's?)?
    Q2 - Calcium seems low. For a new plaster pool what is the recommended range for this?
    Q3 - I am fairly sure that the salt calculation is high (4600). I only added 720 #'s of salt to a 30,000 gallon pool (pool size is pretty accurate based on the shipped in truck water). Based on the salt I added, the ppm should be around 2800 + salt in the fill water (around 200ppm - is that possible?) = 3000 ppm. The SWG concurs and reports between 3000 - 3100 ppm. Still have problems with the salt calc? BTW - I repeated the test 3 times with similar results
    Any other tips is appreciated!
    John
    JonnyG (Hunterdon, NJ)
    30,000 Gal IG Shotcrete (Carlton Pools)
    SW Generator
    6ft Sheer Descent
    Jandy equipment (60sf DE filter)
    Zodiac Mars booster pump cleaner
    Teledyne Lars 400,00 Btu heater
    BBB believer
    Saint Cloud, FL
    Default Re: Another . . .new PS234 results on "new" pool
    Quote Originally Posted by JonnyG
    FC - 3.0
    CC - 0.0
    TC - 3.0
    ALK = 100
    CAL = 210
    CYA = 30
    Temp = 84
    SALT = 4600
    50 ppm is fine for the CYA but I would not let it go lower until you are more familiar with SWCG.
    Calcium level is fine. It will start to go up as you brush and vacuum to waste.
    Q3 - I am fairly sure that the salt calculation is high (4600). I only added 720 #'s of salt to a 30,000 gallon pool (pool size is pretty accurate based on the shipped in truck water). Based on the salt I added, the ppm should be around 2800 + salt in the fill water (around 200ppm - is that possible?) = 3000 ppm. The SWG concurs and reports between 3000 - 3100 ppm. Still have problems with the salt calc? BTW - I repeated the test 3 times with similar results.
    Make sure you are dividing the drops by 2 to bring it line with what the SWCG says. i.e. read the salt testing instructions carefully!
    Try to get the pH down to 7.2 - 7.4 with Muriatic Acid
    John
    Have fun with your pool.
    Pat
    Ft Lauderdale, Fl
    John,
    Are you sure your pool is 30,000 gallons?
    720 lbs of salt (plus the 200 estimate for the trucked in water should be good for 30,000 gallons). However, for it to increase to 4600 ppm, would mean that your gallons is....gulp....less, approximately 18,000 - 19,000 gallons.
    Another possibility is that your salt chlorine generator needs to be salt calibrated. Please make sure, as PatL said, that you followed the directions for the salt test.
    Sean Assam
    e-mail: sean@teamhorner.com --- www.autopilot.com - www.aquacal.com
  1. Newbie just beginning to understand "free" and "total" chlorine. . .
    By Hainsworth in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2012, 10:17 AM
  2. Can a leaking Jandy "Check Valve" with clear top be "fixed"?
    By 105ex in forum Pool Equipment & Operations
    Last Post: 05-29-2010, 08:17 AM
  3. Changing AG pool depth from 52"-54" to 46"-48" for kids (shallow end tricks)
    By zephans in forum Above-Ground Pool Construction & Repair
    Last Post: 06-02-2007, 11:28 AM
  4. New ps234 kit, first results, becoming "kit owner"
    By faginbagin in forum DPD-FAS based testing
    Last Post: 06-21-2006, 06:15 PM
  5. Esther Williams "Millenium" Pool Install "issue"
    By mrpurrhead in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2006, 10:34 PM
