Thread: Straps Under Line
    Dec 2005
    Default Straps Under Line
    Hi About A Month Ago I Had A 15 X 30 Ew Ag Installed.
    I Seam To Be Having A Problem The The Side Rails Of The Pool Have
    Bands The Go Across The Pool Under The Sand. From Outside Of The Pool I Am Starting To See One Of The Bands Through The Water
    From Inside The Pool I Can Now Feel The Lip From The Band.
    Does Any One Have Any Suggestions.should I Call The Installer.
    Default Re: Straps Under Line
    Sounds like they didn't add enough sand. I believe those straps need to be covered.
    Correct. And even worse the straps are very sharp against the liner. A tear caused by the straps could empty a pool very quickly. Yes, call the installer ASAP.
    Dennis
  1. Air Line
    By ts8181 in forum Pool Equipment & Operations
    Last Post: 10-03-2011, 09:55 AM
  2. Air in suction line.
    By kbs in forum Pool Equipment & Operations
    Last Post: 05-19-2008, 08:36 PM
  3. In line strainer ?
    By Phillbo in forum Pool Cleaning: Manual or Automatic
    Last Post: 09-08-2006, 01:44 PM
  4. Replacement Solar Reel Straps
    By PhantomAndy in forum In-Ground Pool Construction and Repair
    Last Post: 05-25-2006, 11:50 AM
  5. Oval construction - straps and uprights uneven
    By NWMNMom in forum Above-Ground Pool Construction & Repair
    Last Post: 05-24-2006, 11:30 AM
