Results 11 to 13 of 13
Thread: how to lower if I need to? alkalinity of 170
    Default Re: how to lower if I need to? alkalinity of 170
    While Steve is right in explaining what T/A does, the levels that are recommended here are pretty simple:
    If you have a gunite/concrete/tile pool: 80-125ppm
    If you have a heater or SWG, generally the same, but the metal composition of both can affect the numbers. Still, 80-125 is safe.
    HOWEVER, if you have a vinyl pool, without a heater or SWG, you can safely go as high as 180ppm without worry. That's a ballpark number of course. You are pushing your luck at 200ppm, especially if that reading is taken at a lower pH.
    While T/A is a "stabilizer" for pH, it DOES go up and down as pH moves. T/A doesn't prevent pH movement, it just makes it harder to happen. It keeps pH from pogo-ing up and down.
    So if you are at the suggested upper limit with a pH of, say, 7.1, then, if your pH rises to, say 7.8, your T/A will probably go well over the max, opening the potential for problems.
    This is why 100ppm is such a good target--there's lee-way either way. For a vinyl pool, you have a far vaster range.
    I repeat: a reading of 170ppm in a vinyl pool without a heater or SWG is FINE and can be left as is with no impact.
    SF Bay Area, CA
    Okay, I found this thread trying to find an answer for my situation and still feel a little lost. Please help. I have Ben's kit and got the following results:
    FC- 3
    CC- 0.5
    pH- 7.5
    Alk- 190
    Cal- 140
    Cya- 35-40 (I'd guess 37)
    I have a heater and a SWG so I'm worried about the high Alkalinity. I just filled the pool about 2 weeks ago after a major remodel. It's concrete with a fiberglass lining. My Autopilot manual says the TA should not exceed 150.
    I saw the other posting referring to a procedure to be followed carefully, but haven't found that procedure just yet.
    about 27,000 gal IG w/spa
    Polaris cleaner
    Autopilot SWCG
    Pentair cartridge filter
  1. Alkalinity stuck at 0...after 50 lbs. Alkalinity Increaser
    By heyaim in forum Dealing with Alkalinity and Calcium
    Last Post: 07-22-2012, 07:51 PM
  2. Help with trying to understand how to get Alkalinity lower
    By Rosie700 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-24-2012, 11:48 PM
  3. Pool store advice to lower alkalinity - three day muriatic acid dose method
    By aquarium in forum Dealing with Alkalinity and Calcium
    Last Post: 07-03-2006, 11:04 PM
  4. How Do You Lower CYA?
    By cheshamjim in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-17-2006, 01:53 PM
  5. Should I lower my alkalinity?
    By dhale63 in forum Dealing with Alkalinity and Calcium
    Last Post: 05-16-2006, 11:21 AM
