Results 1 to 4 of 4
Thread: Heater help
    beary is offline Registered+ Thread Analyst beary 0
    Dec 2005
    Default Heater help
    Hi All, anyone know where to find information on pool heaters? Is one better than the other? We are building an 18 x 38 foot pool and I'm having a hard time finding comparision reviews on heaters. What is your experience?
    Beary
    Downingtown, PA
    Default Re: Heater help
    There are a lot of heater posts so I would search the forum for the type of heater you are looking for... heat pump, gas/propane heater or solar. Each has positives and negatives so it would be too much for one post.
    Outside of Philadelphia, PA
    18' x 40' IG - 22K gallons
    Sylvan Gunite Pool (1979)
    Plaster re-done (1997)
    48 Sq Ft Hayward D.E. Filter (2003)
    1.5 hp Hayward Super Pump (2006)
    mkelley is offline Registered+ Thread Analyst mkelley 0
    I'll give you *my* experience -- after spending $1K (no kidding) on our gas bill one month for heating the pool we switched to solar and never looked back.
    Given today's rising energy costs I don't know why anyone would consider anything else. I love my solar system.
    mbar's Avatar
    mbar is offline Lifetime Member Whizbang Spinner mbar 3 stars mbar 3 stars mbar 3 stars mbar 3 stars
    Ashland, PA
    I have a gas heater, and now I am going to have solar installed. If I had it to do over again, I would just install the solar - the gas is very expensive, therefore I don't use it much. Once you have the intial cost of solar, the everyday expense is 0! Just my 2 cents.
    Northeast PA
    16'x32' kidney 16K gal IG fiberglass pool; Bleach; Hayward 200lb sand filter; Hayward pump; 24hrs; Pf200; well; summer: none; winter: mesh; ; PF:7.5
  1. SWG and gas heater
    By BigSplash in forum Pool Equipment & Operations
    Last Post: 07-23-2009, 04:08 PM
  2. SWG before heater?
    By NomenNescio in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-08-2007, 01:06 AM
  3. Hi-E2 Heater ?
    By fjava in forum In-Ground Pool Construction and Repair
    Last Post: 07-19-2006, 05:52 PM
  4. Heater
    By hancop in forum In-Ground Pool Construction and Repair
    Last Post: 07-19-2006, 02:15 PM
  5. Can't run heater below 40f???
    By cruzmisl in forum Pool Equipment & Operations
    Last Post: 06-17-2006, 03:51 PM
